Bi-X: W203/CL203 OEM Bi-XENON Upgrade, Auto-Levelling & Programming thread
Old Apr 11, 2008 | 12:45 AM
  #2001
Moviela's Avatar
Mercedes offers a kit to upgrade to Bix. The retrofit instructions tells the installer to update the vehicle data card to reflect that Bix has been installed. If the dealer had done this, the parts would show correctly when parts are ordered from the VIN.
My take on the warranty is Daimler is responsible, even if MBUSA is not. The duration of the warranty for electrical parts should be until the new car warranty expires, or 1 year, which ever is longer. Sometimes, depending on your state, you enjoy a warranty that does not need to be writen by the manufacturer.
If you added a CL cluster, or S class tail lights, those types of mods would fall outside the warranty. Mercedes does make some kits to modify C class cars. If you add Bix, Satellite radio, AMG twice pipes (dual exhaust), or telephone completer kit with new genuine parts, you should enjoy a warranty.
Old Apr 11, 2008 | 02:27 AM
  #2002
andy_meng1024's Avatar
2003 SL55, 2010 C63
Originally Posted by coin
I'm selling my set, that's what I mean
Do you want to sell me only the right side?
Old Apr 11, 2008 | 02:29 AM
  #2003
2003 SL55, 2010 C63
What should I tell the dealer in order to re-gain my warranty? Have you had any experience about this before? Thanks.
Old Apr 11, 2008 | 05:39 AM
  #2004
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
sounds like the problem with the ballast. check with Hella if they can do anything for you.
sucks, but dealership won't warranty a product they didn't sell it to you even if they are OEM. BUT if your service advisor is nice enough he can simply use the part number instead of the vin number to order the parts for you under warranty.
Old Apr 11, 2008 | 06:30 AM
  #2005
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
The point here is that he didn't buy the parts from MBUSA/dealer but an outside online source. Therefore that statement doesn't carry any weight with MBUSA. That is regardless or not on dealer installation.
Old Apr 11, 2008 | 11:05 AM
  #2006
coin's Avatar
'06 CLK500
Buy the whole set and sell yours on ebay.
You might roughly lose $400, but at least you get headlights with no broken tabs
Old Apr 11, 2008 | 12:23 PM
  #2007
powa's Avatar
C320 Coupe
http://cgi.ebay.com/ebaymotors/ws/eB...232313348&rd=1
I found someone that's only selling the right side so it's perfect for me. It says one of the mounting tab is broken; can I still use it without problem? Does the price look reasonable? Thanks.
Mounting tab is very important, with broken mounting tab = useless headlight. I strongly do not suggest you buy that.
In your case, see which part of your headlight is broken, is it the bulb? the ballast? the ignitor? get a local auto shop to diagonistic for you to see which part has problem. Stay away from stealership cuz they are expensive and... most importantly however, is that if you use the same OEM part again, you probably will get the same problem today.
What i did a couple days ago, which Im telling you, my OEM Bi-xenon ballast burnt out for the 2nd time (ya thank you OEM MB part). I decided to go for aftermarket ballast, have local auto shop to install it for me, of course some re-wiring needs to be done, but the mechanic knows what they are doing.
Using this method saves you lots of money, in the short run and in the long run.
Old Apr 11, 2008 | 12:52 PM
  #2008
MJ50's Avatar
Super Moderator
bone stock E55 AMG
just get the right side from that ebay and then swap the ballasts...
Old Apr 12, 2008 | 05:14 AM
  #2009
2003 SL55, 2010 C63
Guys, thanks for all the replies and suggestions.
I don't think the problem was the ballast tho, because last week when the light was still functioning, it felt like the whole kit inside the housing was shaking. It was kind of like missing a screw or something like that so the inside part was not secured. Anyone know what the problem might be if the ballast wasn't gone bad? About a month or so ago, I had one city light fell into the Bi-Xenon housing, could this be the reason causing the problem?
I'll go to a few auto shops on Monday and see what they can do about it. I'm also waiting for my dealer to call and tell me how much he wants this time. We'll see.
Old Apr 20, 2008 | 07:46 PM
  #2010
aolsen's Avatar
2013 S550, CLS500, ‘03 SL500, “92 190E Sportline
**Need a Bi-Xenon Ballast W203**
Looking for a ballast for my '03 C230. I have factory Bi-xenon. I've found some used ones on ebay, but if you guys have any new/used ones that you don't need, let me know. Thanks!
Old Apr 21, 2008 | 01:52 PM
  #2011
aolsen's Avatar
I found one on ebay from a 2005 S Class...it has the same exact part number as my ballast. Will this work for my car?
Old Apr 22, 2008 | 07:01 PM
  #2012
2003 SL55, 2010 C63
I've been to the dealer and a couple shops that work on Mercedes in my area. All the answers are the same and I need to replace the whole headlight assembly. The bulbs are fine but the whole thing inside the headlight housing is moving. So anyone is willing to sell only the right side Bi-Xenon or just have one sitting around please PM me the price you want for it. Thanks.
Old Apr 22, 2008 | 07:49 PM
  #2013
kevblah's Avatar
E90 M3
good luck! i spent like a month and a half looking for one, but i finally got it!
Old Apr 22, 2008 | 08:11 PM
  #2014
C24owner's Avatar
'08 E550 4Matic
Why don't you take the headlight apart and fix it? There is no need to buy anything. Use the DIY I posted and take the lens off. Then all you need to do is pop it back in. When you have the lens off you'll know what to do.
Old Apr 23, 2008 | 09:10 AM
  #2015
kmpres's Avatar
2004 c230 sedan
Question Bi-Xenon help (search done)
My 04 c230k ss has the bix from the factory and my auto level feature no longer functions. Is the HRA sensor on the right side sway bar the only thing to control the self leveling for both the lights
Old Apr 23, 2008 | 11:04 AM
  #2016
MJ50's Avatar
Super Moderator
bone stock E55 AMG
yes
Old Apr 23, 2008 | 11:35 AM
  #2017
kmpres's Avatar
2004 c230 sedan
Smile
thanks mj50.
Old Apr 25, 2008 | 11:56 PM
  #2018
aolsen's Avatar
UPDATE
Received the ballast and it works fine..Mods please delete this thread.
Old May 2, 2008 | 05:03 PM
  #2019
mbc230sc's Avatar
C230 Coupe
Question Buying OEM Bi-Xenon Headlights From Ebay ?
I happen to locate some Bi-Xenons for my coupe, this is a must have mod. Anyways I am going to buy them for $825 from the seller shipped is this a good price ? He mentions that the high bidder was from another country so he will sell for lower since buyer screwed up his auction. Also is install hard ?
http://cgi.ebay.com/ebaymotors/MERCE...spagenameZWDVW
Old May 2, 2008 | 05:35 PM
  #2020
mbc230sc's Avatar
C230 Coupe
The seller also mentions plug play so I do not need anything additional right ? I just want to make sure before I buy.
Old May 2, 2008 | 05:45 PM
  #2021
Buellwinkle's Avatar
They will fit the opening, they will not work or play by just plugging them in. You need to have someone with a star diagnostic computer set your xenon=present option on. Otherwise you will get a bulb warning on your dash and the lights will cycle on and off.
Old May 2, 2008 | 06:19 PM
  #2022
mbc230sc's Avatar
C230 Coupe
How much does that cost ?
Old May 2, 2008 | 06:45 PM
  #2023
mbc230sc's Avatar
C230 Coupe
Also are there install instructions can I install myself ?
Old May 2, 2008 | 07:05 PM
  #2024
valexv's Avatar
02 cl203
search the DIY section for the install, pretty easy. I did mine. Programming cost depends on the dealer. Some if lucky are free, others charge up to 150.
Use paypal only for the ebay purchase.
Old May 2, 2008 | 07:08 PM
  #2025
mbc230sc's Avatar
C230 Coupe
Im sending a money order. I dont have a paypal account. How do I get one ?
You have already rated this thread Rating: Thread Rating: 21 votes, 4.81 average.
