Brake Replacement
Brand new to this site. Appreciate in advance everyones feedback and guidance. I have a 2015 C400 55kmiles. I need front brakes and I'm looking to change myself. Just wondering if there is a way to tell ahead of dismantling everything if I would need to change the rotors as well. Would love to save some time/money and simply change the pads only but looking for guidance..
Thanks all!
I’d say Stick with genuine MB or ATE for peace of mind. I’ve done genuine MB rotors and ATE pads on mine.
Thanks all!
On the C400 fronts you will see a small dimple on the face (at the end of drilled holes, every other pattern), if that is worn to nearly flush, that is a good indicator the rotors are at their min life. I run EBC yellow pads and OE rotors and get consistently 20k out of them. Rotors are always at min when the pads are done.
Appreciate everyone's replies but want to learn the right way to do it.
Thanks!
~Rx
Thanks!
~Rx
Or the jack pad: https://mbworld.org/forums/c63-c63s-...63s-coupe.html
No idea about shipping to the UK however - I can say from multiple experiences that getting goods online from the UK is either no longer offered, or with additional charges and local taxes depending on the supplier. To Belgium anyway.
Question - is there any type of reset on the dash needed to tell the car I changed the pads or do i just have to exit the fitting position and drive?
Thanks again
Rx
Thanks again
Rx
