C63 AMG (W204) 2008 - 2015
What did you do to your C63 today?
Old Apr 4, 2025 | 10:01 PM
  #376
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Originally Posted by Accidental L8 apex
Very nice, I actually do have a blower. I'm more interested in what this thing will do in handling and braking with 700 less pounds to throw around though. For me, 3,200 lbs would be about perfect for this chassis. Maybe someday when I'm not dailying it anymore.
It's completely different. Took me a bit to relearn how it behaves.
Slower tight corners it still has more understeer than I'd like with 275s up front but I'm working on more front downforce and a balance change.
It loves long sweepers. Having 400+ lbs rear downforce at 200kph helps though.
Old Apr 5, 2025 | 12:39 AM
  #377
Phil_T's Avatar
C63 AMG Saloon
Originally Posted by Jasonoff
Last time I had it on the scales it was 3380lbs. It has since had more weight stripped so it could be high 3200 to low 3300. The factory says it's 3924 but mine was just a smidge under 4000.
A 7-800 lbs loss is like having stage a 1 SC. I have been asked which blower I have a few times
After the seats where were the biggest weight losses?, I will be changing the seats in mine, loosing the rear seats and deleting the sunroof with an oem non sunroof panel and I can save between 80-100kg with that. Id like more weight out but I want to keep the carpets and door panels. Already saved 22kg with wheels, brakes & suspension so no more to be saved there.
Old Apr 5, 2025 | 08:23 AM
  #378
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I didn't weigh individual parts. Things that stood out was the ac compressor, sunroof, door glass and the dash. All the little modules that control things add up quick too.
The carpet had some heft to it.
Old Apr 5, 2025 | 10:51 AM
  #379
Accidental L8 apex's Avatar
2013 c63 Magnuson SCed
So did you have the roof reskinned with steel or aluminum then? I'd be interested in doing that way before any other weight savings since it's hot in the Summer and noisy all damn year.
Old Apr 5, 2025 | 12:11 PM
  #380
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I used 1/4" polycarbonate to fill the gap. Rubber window moulding with 3M window adhesive to secure it.
Old Apr 5, 2025 | 08:31 PM
  #381
Ah, I was confused and thought you'd ditched a pano roof.
Old Apr 7, 2025 | 10:46 AM
  #382
flsupraguy's Avatar
love it!
Old Apr 9, 2025 | 06:34 AM
  #383
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
First pass at choppy choppy. Have since cleaned up the 2 ends after removing the spring to cycle the suspension and trim for clearance.
Old Apr 16, 2025 | 01:03 PM
  #384
marcd7tx,'s Avatar
I washed and drove it.
Old Apr 16, 2025 | 01:49 PM
  #385
svtjocson's Avatar
2010 C63
prepped cf dadsc63 hood and cf fenders for paint
Old Apr 19, 2025 | 12:25 AM
  #386
1MBsleeper,'s Avatar
I got new sets of pirelli tires
Old Apr 19, 2025 | 06:45 PM
  #387
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Not winning any style points but it should be functional with a 295 back there.
Old May 29, 2025 | 10:47 AM
  #388
sickSVT's Avatar
Top Answer: 1
3.0L Whipple E63 AMG
Finally got my Recaro Pole Position seats after 7 months wait caused by their bankruptcy, they started production again a few months ago but have a huge backlog of orders. Hopefully I can install them over the weekend.
Old May 29, 2025 | 12:27 PM
  #389
deadlyvt's Avatar
2010 C63 AMG
Looks good. A mod I want to get done should get on it soon probably be a wait for a while on those
Old May 29, 2025 | 02:22 PM
  #390
Any idea on weight savings with those?
Old May 29, 2025 | 06:04 PM
  #391
Highline-Autos.com's Avatar
SPONSOR
2001 E55AMG
Looking good! The delay was brutal, but wouldn't believe the number of orders we've had to turn down since, so better late than never!
Trenton O. Gibson
tgibson@highline-autos.com
Highline Autos
Direct: 602.909.9216
Office: 480.348.0777
Old May 29, 2025 | 06:28 PM
  #392
sickSVT's Avatar
Top Answer: 1
The wait time sucked for sure, hopefully they get caught up soon.
Recaro seats with mounting brackets around 35lbs each, my stock E63 seats are probably over 70lbs each so it should be a nice chunk of weight savings.
Old May 29, 2025 | 06:32 PM
  #393
sickSVT's Avatar
Top Answer: 1
Trenton O. Gibson
Highline Autos
It was worth the wait for sure! Thanks for the pleasant experience and constant communication with updates.
Old May 29, 2025 | 06:40 PM
  #394
SPONSOR
2001 E55AMG
You bet my friend!
Trenton O. Gibson
Highline Autos
Old May 30, 2025 | 11:49 PM
  #395
svtjocson's Avatar
2010 C63
Got the new wheels/tires on, ready to start cutting the rear flares
Old Jun 1, 2025 | 09:22 PM
  #396
svtjocson's Avatar
2010 C63
Could you share some more info on this? Did you cut the polycarbonate yourself? How's it holing up now that a little time has passed? All you did was remove the glass, wiring and motor? This seems like a more tangible option than getting a cf roof fabricated or swapping the roof from a no sunroof optioned w204
Old Jun 2, 2025 | 07:56 AM
  #397
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Sunroof Steps:
  • Remove complete sunroof.
  • Tape template material onto the roof to trace the opening from inside the car (I used thick underlay paper)
  • Draw a cut line on the inside of the trace minus the thickness of whatever molding you use with some wiggle room to create a template.
  • Use the template to cut out the polycarbonate panel. (I used a Jig Saw with a fine tooth blade for plastic)
  • Tape the window molding to the poly panel so you can do a dry fit first.
  • Glue the molding to the poly panel.
  • Glue the assembly into opening (just like you would with a windshield. I used 3M window adhesive)
  • I had to use weights on all 4 corners because of the roof contour and left it on for a day or so. (Whatever the cure time was on the adhesive)
It was relatively simple, just time consuming. Has been in the car since 2021 without issue.
Old Jun 2, 2025 | 08:20 AM
  #398
svtjocson's Avatar
2010 C63
Sunroof Steps:
noted, thank you
Old Jun 2, 2025 | 01:02 PM
  #399
Phil_T's Avatar
C63 AMG Saloon
Sunroof Steps:
Did you happen to weigh the sunroof when removed? Ive got a brand new standard w204 non sunroof full panel to fit at some point. It would be nice to know how much weight I will be saving before I get round to it in the distant future. I guessed about 22kg with the glass & frame.
Old Jun 2, 2025 | 02:22 PM
  #400
Mort's Avatar
The weight of the sunroof is 75 lbs. according to post #67 in this thread: https://mbworld.org/forums/c63-amg-w...-thread-3.html
May be more information in there if you dig around a bit.
