Is the conductor plate a DIY job??
2002 CLK430
Hello,
After searching on this site I have found that my problem is almost definitely the conductor plate. (Gets stuck in 3rd gear, turn car off and on and problem goes away.) Is the conductor plate a DIY for an experienced shade tree mechanic or does it require dealer programming or special tools? From what I can find it looks to be pretty straight forward. I just haven't seen anybody do a write-up.
2002 CLK430
Wow, nobody has done this repair on their own? I was able to find some schematics and it doesn't look like any special tools are needed. The only problem I can see is that it might need some programming but that doesn't seem likely.
2000 CLK 430
Never heard or seen it discussed here on the forum....doubt there are many out there who have done it, if Marcus or Ash dont know then you are pretty much on your own.
2002 CLK430
I've found a dozen threads where the problem is diagnosed as the conductor plate but no write ups or people mentioning that they did the work themselves. From what I can tell, after you drop the transmission pan it is right there, ready to be removed.
2002 CLK430
I've had the job done. I started a thread years ago when it failed. I have competent mechanical skills (have rebuilt more Porsche engines than I can remember). That said, I personally wouldn't do the job if it failed again. I'd take it back to the dealer. A DIY type "could" do it. However, after the plate is changed, I think a STAR box is needed to clear the code. My reader wouldn't clear the code after a restart.
2002 CLK430
I just finished replacing mine on Sunday. I had to do it on jack stands and that's a bit tough.
The hardest part was removing and replacing the 13 pin connector harness sleeve. It's tight above there in the CLK55.
I also found there was no covers on the shift solenoids. Does that sound rite?
So at this point I now need to have the code cleared.
I;d say it was a intermediately tough job. Relative to my ability that is.
And it's warm where I am, that can make or break a job for sure.
For tools you'll need a 7 MM deep socket for the connector harness sleeve removal and I also needed a few extensions and swivel to get to mine.
A torx 30 bit for the valve body bolts.
And a 5MM Alan head for the pan plug.
The pan bolts were either the 5MM ot the toex30, I already can't remember.
Here is a video of someone doing it on a ML. This helped me although it is not too thorough.
(Part1)
(Part 2)
(Part1)
StradaRedlands (07-16-2017)
2002 CLK430
That's exactly what I wanted to hear. I have read that not all of them have covers over the solenoids. It sounds like some of the replacement kits comes with them. If they aren't there it is ok. How does your car drive since you did it? Any issues with the the codes being left in there? What I am wondering is if I can just leave them in there until I actually need to go to the dealer. I live 3 hours away so I would rather not spend 6 hours just to reset the TCM.
I haven't found a place to reset the codes yet, my car is not a daily driver.
My OBDII doesn't erase the code and I've had negative responses from the local German car shops around here.
Here's the thread on where I stand:
https://mbworld.org/forums/mercedes-...ml#post5578667
Krazzz, where do you live that the closest dealer is 3 hours?!
Look up how to do a transmission service, thats a good part of what you have to do. So familiarize yourself with that part of the conductor plate job.
2000 CLK430 Cabriolet
The dealer will bill you $2,000+, but they are thieves. In fact, if you ask the dealer for a quote on the job, they will despise you because you already know too much, since they normally stick their customers for at least $6,000+ for a transmission replacement/rebuild.
I was going to do it myself last year, but I found an indie that did it for $650 total, included the parts.
The plate from the dealership was $306, same OEM from parts.com was $196.
Look for an indie.
Look for an indie.
2002 CLK430
I decided to do it myself. The parts are ordered and will be here next week. I'll be able to do the whole job plus some extras for under $300. A buddy of mine is a mechanic and we did a test run with his code reader and it will read and clear tranny codes so I am all set. I'll post again when I am done.
02 clk 55, 13 GL 450
2002 CLK430
It is a top of the line Snap on. He had to use a special cable and a chip that he adds to the machine. He had never used it on a Mercedes before (not many of them around my area) so he wasn't even sure if it would work. Looks like it will read everything on the car.
2002 CLK430
I did the job this weekend and the results were better than expected. I replaced the conductor plate, fluid, filter, solenoid swap and the Sonax overlap valve upgrade. It shifts like butter!! So smooth. The whole lifetime fluid idea is nuts. At 95K miles this fluid was junk. I couldn't imagine driving any longer on it. I'm going to drive a couple weeks and do another fluid change and then repeat one more time. Also, my car never went into limp mode and drives perfectly. I'm still going to take it to read and erase the codes so that if I have future problems I will know they are fresh codes. Overall this was not a difficult DIY. This was maybe a 4 or 5 out of 10 on the difficulty scale.
It's great to get feedback like yours.
Congratulations.
I know this thread is old but replacing the conductor plate really isn't that bad of a job at all. I've heard of repair quotes upwards of $1000 and that's highway robbery. I think the key to success is buying a quality conductor plate. What led me to doing this job is that the car is about to turn 100k miles, fluid color looked more like lightly used motor oil and my 1-2 up/down shifting seemed a little sluggish. Upon disassembly I did find my harness connector full of fluid. My plan is to flush the old fluid when it all goes back together.
I'm doing this in my garage on jack stands...I wish I had a lift!
Here's a good DIY on replacing the conductor plate on a 722.6.
My costs so far are:
-(3) 5 liter jugs of Pentosin ATF 134 from Rock Auto $117 shipped (bought this much fluid to flush trans)
-Conductor plate, drain plug gasket, dipstick pin FCP Euro $182.71 shipped
-Filter +gasket $14.60 Amazon
-Shift solenoid o-rings $15.92 shipped Cobra Transmission
-Transmission harness connector $3.55 Amazon (rolling the dice on this one although it had good reviews).
TOTAL $333.78
I pulled everything last night and will be reinstalling today. I'll report back on results and if my cheap connector bites me in the *** or not. I also thoroughly cleaned the harness plug with brake parts cleaner to remove any fluid and blew it clean with compressed air.
Here's another useful troubleshooting link if you'd like test your conductor plate, ohm test solenoids, pin locations, etc.
https://www.techtips.ie/febi/mercede...ctor-plate.pdf
I cannot stress the importance of a clean surface when doing transmission work. I bought this pan for rebuilding carbs years ago and it’s great for this.
TOTAL $333.78
Thanks for your efforts to better show this work. It is SOOO welcomed.
One point I would like to make is- do not use the harness connector screw to pull it into place. The threads inside are plastic and you can easily strip them. Instead, push it in as far as possible then snug it up tight with the screw. Perhaps someone could give the torque measurement. But I was advised wrong and stripped mine then I had to redo the job a few months later including another conductor plate..
