How to repair the AC system Part1
Assuming this works, attached are 5 of 15 files that contains PDF pages from the offical MB workshop on how to:
Replace the compressor
Replace the dryer
Replace the expansion valve
Also included are oil capacities when replacing all components or individual parts such as just the expansion valve.
I will forward the other PDF's in two other messages.
This works for any W210 chassis - mine was a E430 2000 year model.
I used these instructions recently to repair my A/C system that required these three parts above. Note that it says to remove the fan when removing the compressor. It is possible to slide the belt out around the fan without removing the fan itself.
The reason there are so many PDF's is becuase some of the MB instructions call out other instructions that have their own document. Basically you can change out any of these three parts in any order - just follow the logic in the MB instructions.
Belt layout.pdf
compressor oil amounts.pdf
compressor oil capacity More.pdf
compressor oil capacity.pdf
Expansion Valve Replacement.pdf
good luck
Replace the dryer
Belt layout.pdf
good luck
How to repair the AC system Part2
here are the PDF's 6-10 (11-15 of 15) to follow in next message
Remove Fan Shroud.pdf
Remove Fan.pdf
Removing Bottom Section.pdf
Removing left air inlet.pdf
Removing Right Air Inlet.pdf
Remove Fan.pdf
How to repair the AC system Part3 of 3
Here are the last set of PDF files 11-15
Removing water collector.pdf
Removing wiper system.pdf
Replacing AC Expansion Valve.pdf
Replacing the AC compressor.pdf
Replacing the dryer.pdf
