E-Class (W211) 2003-2009
Old Jun 10, 2015, 12:13 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Brake Guides
Print Wikipost
W211 DIY Brake Job
Old Oct 27, 2006 | 03:19 AM
  #76
points's Avatar
sorry i own a volvo but saving for a merc
what did i do wrong
i live in spain and getting any information from mb is imposible.
i have a small fast fit center and when i had to change pads on a w211 i did it the normal way...took wheels of and pushed calipers back refitted pads..
then came the scary part,i moved the car and the pedal just went to the floor.
i left the car for about 15 min and then everything was ok.
so my question is ...when you disconect the sbc then reconect it do you have to wait for the breaks to ajust themselves ?
Old Oct 28, 2006 | 07:39 AM
  #77
X72's Avatar
X72
Honda Accord
points, see my post in this thread https://mbworld.org/forums/e-class-w211/168130-05-cdi-brake-job.html
There is a link to another thread at tech.bentleypublishers.com that has a pdf file describing the correct procedure for initializing the new pads. It is good because it reminds you to lower the brake fluid before you lock up the car. It worked on my 03 E320, but I don't know if that will work on later versions though.
Old Dec 26, 2006 | 02:20 PM
  #78
dannieboiz's Avatar
08' S550, 04' E320 4matic, 03' Acura TL-S 6 speed, 1968 Vespa P150
guys quick question. I'm only doing the rear today. Do I have to unplug the SBC as well?
Old Dec 26, 2006 | 08:39 PM
  #79
wingless's Avatar
Debadged 6-Speed '05 C320 Sports Coupe
The GiroDisc caliper spreader from Zeckhausen Racing is an excellent tool when changing pads. It is very easy to bottom-out the pistons.
This was used on my recent rear brake job, with lots of images attached.
Old Dec 26, 2006 | 09:44 PM
  #80
dannieboiz's Avatar
no need for such a gaget. I just finished doing my rear brake pads using just a large wood clamp. my C clamp was too small.
I couldn't get my darn rotors out since I didn't have the 8mm screw long enough to drive it out so I just did the pad. My rotors looks just as thick as the new one which really raise a question if I really needed to do my rotors. Works fine and warning lights are off. I might just go return the rotors and save myself a hundred bucks and do slotted/cross later on all 4.
Old Dec 26, 2006 | 10:44 PM
  #81
oofie910's Avatar
06 330i, 06 E350
Anyone know where I can buy cross drilled slotted rotors for a w211? I might do the brake job on my dad's car and would want to also change the rotors on the car.
Old Mar 24, 2007 | 07:01 PM
  #82
gabby188's Avatar
Originally Posted by burkett
This was the easiest brake job I have EVER done (less than 20 minutes)...and I've done quite a few on different autos. And the cost to do this yourself is astounding ($102 vs $530 dealership quote). Here is a series of photos that may help others in their attempt.
1. Apply the parking brake, pull the hood lever, exit the car and set the key aside.
2. Open the hood a locate the SBC connector
3. Pull up the SBC Clip to unlock the connector
4. Pivot the connector backward to disengage and set aside
5. Lift car and remove tire. This is the before shot
6. Unplug Brake Pad connector and sensor
7. Tap out holding pins (I used a thin drill bit and a hammer to do this)
8. Remove pad holder
9. Compress piston using c-clamp or carefully with pliers (Not much force needed). DO THIS WHILE OLD PADS ARE STILL IN THE ASSEMBLY
10. Remove pads
11. Insert new pads
12. Re-insert pins
13. Hook pad holder under first pin then press down and insert second pin
14. Replug sensor and connector. I had to used the old one since Mercedesshop did not send that sensor for this side...even though this one is still unbroken I will replace tomorrow after purchase locally
15. All Done
Hope this helps someone!
Would you please repost the pics of the SBC disconnect. They did not come through. Thanks
Old Apr 18, 2007 | 01:50 AM
  #83
Kimber's Avatar
2005, E500 Designo
E500 Brake Job
Is this procedure the same for an 2005 E500? How do you turn of the tow mode?
Old Apr 21, 2007 | 04:59 PM
  #84
Htowncls's Avatar
CL63
Burkett,
I dont know if your active on this board anymore as this is a very old thread but I wanted to thank you for your photos.. I changed out my front pads on my CLS today with Porterfields and your photos made it very easy..
thx,
Htown
p.s. by the way you dont have to disconnect the SBC while doing just a pad change if you dont want too.. Just open the hood and dont allow anyone to open any doors or trunk while you are working on the car.. more importantly your fingers should never be in front of the pistons anyway.. Pull the old pads out by the top of them and hold the new ones in the same place.. your fingers will never go past the top of the caliper.. don't forget to squeeze the pistons closed while you still have the old brake pads in with clamps or regular plyers and you should be good!
Old Apr 21, 2007 | 05:10 PM
  #85
starbrite's Avatar
2004 E320
Originally Posted by Htowncls
Burkett,
His last post was December 17th, so I doubt it.
Old Apr 25, 2007 | 03:01 PM
  #86
angeleye328i's Avatar
I did my brake and rotor last weekend on a 2004 E320 and it was a piece of cake. Took me about 1hour to do both front and back. What I learn:
1. If you change brake pads before on any car, then its the same procedure
2. You don't have to unplug your SBC or whatever they called it
3. Go to your local autoparts store and buy the vice to push your calipers so that it will fit your new pad.. cost $9.99 makes the job WAYYYY easy.
4. Leave your old pad on when you use the vice
5. Brake cleaner everything (except the new pad) this way everything is nice and clean.
Old Apr 25, 2007 | 03:21 PM
  #87
starbrite's Avatar
2004 E320
Also a good idea to put a little high adhesive/high temp copper paste/lube between the piston and back of the pad to prevent squeaking.
Wurth CU1100 for example.
Old May 17, 2007 | 07:01 PM
  #88
dannieboiz's Avatar
I just got off the phone with the parts guy @ MB he told me that the front brakes actually have 2 sensors? A 50% sensor and a replace now sensor. Sound about right?
Old May 17, 2007 | 08:25 PM
  #89
mestizlove's Avatar
2006 E350
any pictures of rear brake diy??
hello everyone ... i'm trying the change the rear pads only,, i assume i have to remove the calipper by 2 bolts,, is this right??
...also anyone got pixs of a rear brake DIY??
all the pictures on burketts album helped alot. i did the both fronts in 30 mins(thanks burkett!!) ..
Old May 17, 2007 | 08:36 PM
  #90
mestizlove's Avatar
2006 E350
Originally Posted by DalBenz
Just completed replacing all 4 corners on my 2004 E320 about 10days ago.
I guess I did it right, so far, no problems!
The hardest part was breaking loose the bolts for the rear calipers. Glad I had my air impact wrench and sockets.
was it 2 bolts??
Old May 25, 2007 | 10:25 AM
  #91
WMC's Avatar
WMC
I have an 97 E420 and will be doing my own front brake pads and rotors soon. Do the 97's have an SBC disconnect? Does anyone have any DIY pics or steps for the procedure on this model?
Old May 25, 2007 | 10:50 AM
  #92
starbrite's Avatar
2004 E320
Note that this is the 211 forum, 2003 and newer. You may want to post
your question in the W210 section.
Old Jul 9, 2007 | 11:45 PM
  #93
LBDOC's Avatar
2003 e320 sedan
brake job
Thanks everyone, thanks to this post I was able to have no problem with an oil change, air filter change and brakes on all wheels for my 03 E320....
Old Jul 10, 2007 | 08:38 AM
  #94
vettdvr's Avatar
03 E500 and Corvette
Correct. I bought the pads / rotors to do my front and what I found was the sensors on the front are at different positions in the pads. Basically the sensor is a copper wire encased in plastic. When the pad wears down the plastic/copper wire wears which results in an open circuit giving the + on the dash. When the second sensor is activated you probably get the (brake workshop alarm but don't know for sure). I took my car to MB for service then 1000 miles later got the +. I measured the pad thickness and compared to the MB spec. When the + showed up it had not reached the MB replace minimum spec. This allowed more driving and safety until the next service. We have 10,000 miles with the + still on and the pads have not reached the minimum spec yet. I plan to change them in 4000 miles which will give me about 14000 more miles of driving w/o reaching the minimum. When the + is on the dealer will want to change them and if you are heavy footed on the brake probably good to change them. But my guess is when the first + comes on you have 10 to 15,000 miles left based upon my wear observed. (your mileage may vary,, Just had to say that )
Jim
Old Jul 15, 2007 | 12:31 AM
  #95
dfoote@sbcgloba's Avatar
E 320 CDI
I just completed front and rear pad replacement on an '05 W211 CDI. 76000 miles on the vehicle. Euro deliver in July '04.
For those of you considering a DIY pad replacement on an 05 CDI, note that the front caliper does NOT have the 2 pins.
It's actually easier.
-Disconnect wear sensor
-Remove two bolts on back of caliper, one on the top, one on bottom of caliper.
-Lift up caliper.
-Pull out pads.
Reverse the steps to R&R
That's all there is to it. I've done the same job on a W210, with the pins, and a pad replacement on my 211 was easier without the pins. It takes about 15 minutes per wheel- and the dealer charges something like an hour per wheel.....
Make sure you disconnect the brake module- and have at it....
I didn't replace the rotors because they didn't need it.....
Good Luck!
Old Aug 3, 2007 | 10:13 PM
  #96
beanieBenz's Avatar
'05 E500 Blk Opal/Stone, 321 AMG Package, Lighting Package, Harmon K., Parktronic, Keyless Go, Nav
Rear Caliper "Secret Bolts"
I was replacing the rear pads on my 2005 E500 Sport yesterday. I couldn't figure out how to lift up the caliper to get the old pads out. The rear calipers didn't seem to have bolts at all. Just a rubber hose knob at each end that felt like it covered a straight pin with no head for turning with a wrench.
I called my mechanically inclined friend over to come and stand baffled next to me. He took one look at it and knew that I needed a Torx screwdriver to remove those two bolts.
Yup inside those two rubber pieces is a size T-40 bolt that needs to be unscrewed in order to be removed. After, finding that out... the job takes 10 minutes per side for pad replacement. Uggh!
Old Aug 14, 2007 | 03:07 PM
  #97
vettdvr's Avatar
Originally Posted by BoughtaBenz
Side View:
Top View:
You can see the black plug in both views.
How in the !##@$!@#$ Sam hill do you get the black plug off. I saw the tap on the top, pulled it and the top of the plug came out, but no way no how could I get the bottom off. I left the top and plugs disconnected then changed the pads. After the pads I plugged it back in. Learned something. I went through the MB brake disable prodecure in addtion to un pluging.
WARNING. the window was down and door locked. So smart me without key fob decides to reach in unlock door to get in and pump brakes.
Didn't know the alarm was so loud,, wow.
But for the first break job all went well. Rotors had .050 more wear in them good for 1 set of pads. Unfortunately the MB supplier sent me 2 right sensors for the pads. So I did the installation and put in the right sensor. Will be a day or so before the other arrives. Could drive it w'o sensor would be like driving with sensor I removed. But too much effort to install tire then pull a second time so I will wait until the Left sensor arrives.
So my summary:
About the easiest brake pad change ever.
Basically
  1. disable brake system,
  2. unplug sensor,
  3. remove lock pins,
  4. compress calipers (I opened the bleed screw to let the fluid out vs pushing it back into the system).
  5. Then remove pads.
As Chiltons woulds reverse removal to install.
I did get a red christmas tree when I put the key in. I started the car, depressed the brake, Shut it off, then repeat the step 1 more time and the alarms cleared.
I am sure I will have to bed the pads in carefully for the first few miles but otherwise it worked out well at least so far. Jim
Old Aug 15, 2007 | 06:42 PM
  #98
vettdvr's Avatar
Ok, front brakes are complete. POC,, easy job rate it 2 on 10 scale.
Most difficult part was jacking and taking wheels off.
Kept the rotors on due to being within factory spec and not needing replacement. Used new pads and sensors.
Red lights everywhere when I powered back up until I got the pads out to the rotor. Brakes worked well.
Now the question. Haven't checked the rears yet, they only have 10,000 miles on them. I still have the + in the FSS indicating brake replacement issue. Is there a reset for the FSS on this brake pad change? thanks Jim
Old Dec 18, 2007 | 12:20 AM
  #99
lasvegas99's Avatar
E500
Some PDF's for the thread
In the interest of keeping all possible resources in one spot in the thread here are the PDF's mentioned in one of the links.
I looked at them quick and they have a decent step by step format.
I have not tried these so I can not back them. If they are not good for any reason, let me know soon and I will delete my post.
File Type: pdf
File Type: pdf
Old Dec 18, 2007 | 09:42 AM
  #100
gnma's Avatar
'12 Mustang 5.0, '89 Supra Turbo, C55,
I realize this is an old post, but I want to thank everyone for this DIY project.
MB owners doing DIY. Who would have thought it!? I love it!! Thanks again!
