Intake valve cleaning in Chicago area?
I haven't actually looked at my valves yet, and I'm not sure if it's really possible without pulling the intake, but the car has 140k miles on it and the valves have probably never been cleaned. Based on the pictures I've seen here, the valves could use a hefty cleaning...
Anyone have any experience around here?
Thanks.
I suggest looking at any M278 engine tear down, any video where they pull the intake, or any video showing the valve cleaning process on an engine with more than 50k miles to see what the issue is before opening your mouth and proving to everyone that you're an anti-social moron.
As an after thought------which family member suggested cleaning the intake valves or did they mistakenly mean exhaust valves
Conventional port injected M272/273 engines wash their valves with gasoline but GDI valves can not.
The best thing to do is recognize than better oil is not vaporized, then no walnut cleaning necessary.
How much oil goes missing between your oil changes ??
Have you inspected your intake valves to see how much carbon has deposited??
I haven't inspected the intake valves yet. Is there an easy way to do it without pulling the intake?
You can borescope or remove intake plenum.
Your engine consumes about 1Qt per 5KMi. Pretty average around 100kMi: Not too bad.
How about you cancel this oiling issue easily for free? Simply use better engine oiling:
Normal oil pump pressure
Ester based API-SP oil
Greater viscosity.
Switch to a quality ESTER 5W-40 oil :
- Castrol,
- Amsoil,
- Motul,
- Mobil1
Better Oil will quit being vaporized under high heat and will remove more piston heat without burning.
Don't bother with intake valves, a pretty low hanging fruit.
Laggy throttle is caused by drafty stuck rings not coated valves.
Cylinder 5 as per 26th June 2021 , no more than 32,000 KM for sure.
Cylinder 5 with intake manifold removed, as per 12th Aug 2022. No more than 34,000KM for sure.
No walnut machine, purely "hand job" , sweat and tears.
The best I could do
I think my fuel comes from Syria or Yemen or North Korea
An articulating boroscope can't do it.
Articulating one is good for piston and valves face
Front and side camera type.
Side camera boroscope, if without aftercooler blocking the main pulley ( M276.8xx Turbo ) and we can spin main pulley easy and see more of the valve back side. This is cylinder 1
Cylinder 1
Cylinder 2
Aha, it was 36,000KM. Sorry, I recalled it was 34,000KM
Yes, 100% scraping by hand...duggghh.
The job is described here : https://mbworld.org/forums/e-class-w...eaning-p2.html
@CaliBenzDriver I already disabled the OPR solenoid, and I'm using LiquiMoly 5W-40.
In times past, I would pull the intake manifold and manually clean the valves myself. Then I would replace the manifold before the flaps break so I don't have to do that job again. Nowadays, I am too busy for something like this so would rather pay someone a reasonable amount of money to do this while I work and get paid... I just don't trust anyone to drive my car, much less disassemble it.
