M276.9 3.5NA engine oil cooler removal, is NOT as easy as M272
Someday you guys will need this.
A member asked me why he could not find WIS for M276.9 engine oil cooler removal procedure.
There is no WIS for M276.9 3.5NA engine for engine oil cooler replacement. Only bolt tightening torque at 8Nm.
None for M276.9 3.5NA engine...........
I am attaching M276.8 3.0TT WIS for engine oil cooler and other supporting documents linked to it, as if it were M276.9 3.5NA
But you guys are lucky, this MB Tech in Dubai had a full video for your M276.9 engine engine oil cooler removal and he does not follow WIS a 100%.
Yep, same pain in the azz but less pain than my pain on M276.8 3.0TT because I have a turbocharge blocking the work.
https://mbworld.org/forums/e-class-w...r-painful.html
Visualization for M276.9 3.5NA below
Photos from : https://www.ebay.com/itm/16579112748...3ABFBMxJP3wuZl
The hiding cavity at engine mount bracket for the oil cooler
Enjoy your preventive maintenance.....
That's two fingers tight!
Why not 25Nm?
What is Mercedes up to here??
Is this a setup for mayo-mixer...
or why so loose ??
Use a piece of wood between the jack and pan bottom: no problem.
The oil pan is not genuine plastic like lighter BMW's...
What amazes me is how well built this is.
The heat exchanger fails
with oil in coolant (dirty radiator)
instead of coolant in oil (dead engine).
https://www.autohausaz.com/pn/MB-2760106507
Perhaps if you want to be safer, add those low cost engine support bar as back up and share the load.
But me I already made in advance my own engine hoist, because I do not like what are available on the market and I wont buy MB reccomended one too expensive.
https://mbworld.org/forums/e-class-w...ml#post8868054
I do not like loading my car for 250kg worth of engine load ( estimated ) at area not meant to carry load.
You get like a crow-bar effect. Not good for the engine to tranny bell housing interface.
I am not familiar with 4 matic oil pan and front subframe/carrier overall placement on the car itself.
Any photo of your under carriage like mine below ?
You mean by NA V6 is the M272 right ? M276 3.5NA is a nightmare too
Lucky you , that 272 is oil cooler replacement friendly
If only to see, you can from top side
Remove air filter intake square pipe like below, you can peek and see like above photo.
My HVAC hose to compressor is very thickly insulated, yours is not, better view you will get
On anything I replace in the car I either sharpie the date and kilometers when it was replaced so that after months and years when I see it I do know the age of those items. Another question for you. What is that thick, orange cable running across your engine compartment?
I could not get black color...LOL.
The insulator for suction hose of AC compressor does help a bit in bad traffic jam. Keep the hose less hot, thus compressor heat load reduced.
Want to see more date labels : ?
Reminder, max 3 years for tranny and DIFF oil.
Brake fluid, 2 years, typical.
Not all I replaced has dates, but their gang member ( group) has date, so easy to remember.
The hoses to firewall, I don't date them but they are 10-11 years max use for me even only at 40,000KM, thus renewed last year.
Thermostat and all coolant handling plastic pipe or fittings and rubber hoses.
Your C43 will need this to be replaced :
Above is NOT fun to do. This pipe connects Bank 1 and Bank2 coolant output and feed it to thermostat. The item is below
A lot more............................. others I replaced.
The most hidden label, but me often goes under the car :
It is close the left side exhaust CAT.
Thus I prepare the back up.
. Can't get black color welding wire, only orange....thus orange it is then.Coolant I replace every 5 years, but at 10th year or less, I replace the coolant recovery bottle.
That bottle contains the addetive "mini-*****" for the coolant. That is why MB has the ba-lls to advice coolant is to last 10+ years.
I don't wait for issues on the car, let alone DTC. Hoses and plastic and thermostat are all preventive 10th year refresh plan.
I like my car feeling like new and and anything supporting flow and handling of coolant, engine oil, tranny oil and brake fluid and fuel , 10 years is good to go, latest 12 years.
That is why I am in a big headache for oil cooler gasket planned to be done this year, seems like turbocharger has to be removed as per WIS.
My biggest headache is the 2 hidden o-rings at timing case cover which carry over coolant to coolant pump and crossing over timing chain region, oil bath region.
Milk shake will happen when these two o-rings get tired and it will get tired. I think by 15th year it will already be a liability.
This two o-rings : https://mbworld.org/forums/e-class-w...r-replace.html
Another o-ring you should watch out for, is the oil suction pipe/baffle o-ring and probably the oil suction pipe baffle plastic itself.
I just posted today : https://mbworld.org/forums/e-class-w...0-p054c00.html
I would say they won't last more than 15 years and stilll in 100% working condition aka zero air suction leak.
Cheap stuff, but replacing them is no fun.
I am keeping my car to at least 20th year. Thus 10th to 12th year is good mid-ownership refresh.
This way I can WOT my engine without worrying ..........
Hot + humid tropical countries do tend to destroy plastic and rubber faster than cooler and lower humidity countries, this is true.
Even the sunlight UV is strong here.
Somethings I just have to swallow due to humidity and age........... like below :
Did some recon last weekend and discovered that the left engine mount is missing the M8 bolt on the rear attach point
Does anyone know what the rust colored object is ? Looks like the end of a bolt threaded from the other side .
Here is the fwd bolt
C class, but the same design as W212
Are you sure ?
A2122403217 Engine Support
Photo not too great a detail......
I don't think MB change the method of M8 securing the engine mount, even if yours is 4 matic.
Mine and W204, the same.
https://www.ebay.ca/itm/127115614601
The right engine mount shows two bolt heads installed from top - not from under sub frame
The left engine mount shows one bolt head in the front and one missing bolt in the back. In other words, there was only one bolt securing the left engine mount to the chassis.
