GL 350 Run flat tires unavailable
CLS55 plus a few Ducati's
2010 GL350 with a tire failure at 33,000 miles and Goodyear currently out of stock of replacement tires in the Continental USA!! I mean WTF! so cannot drive this vehicle for 3 weeks until stock arrives. This is just deplorable.
Anyone have any ideas?
Thanks in advance
Thanks in advance
Forget about Run Flats and buy regular tires. If you'll get size 285/50/20 - you'll save even more.
Get this thing instead of spare : http://www.ebay.com/itm/400247804177...ht_2655wt_1344
Bridgestone run flats are better & cheaper. Where are you located? Have 2 near-new Bridgestones sitting in my garage that I'd be willing to sell. I'm located just south of Modesto, ca.
Btw, I for one am a fan of the run flats. Sure they ride rougher, are noisier, and are unreasonably expensive, but they came in REAL handy one time already. Hit a huge pothole in the middle of the country at about 1am (pitch black, nowhere safe to pull over, no cars around), which ended up bending a wheel & flattening a tire. Because of the run flats, I was able to limp home at 45 mph instead of sitting out in the middle of nowhere, waiting for a tow truck.
Sometimes the tradeoffs are worth it..
or buy a doughnut spare: http://www.ebay.com/itm/230806359288...84.m1555.l2649
Guys.... thanks so much for the comments and ideas.
I am in Seattle.
I did some research and was told that the Bridgestone was not a run flat tire.... was this incorrect??
As far as the spare goes I will try to determine if it will fit in place to the tool tray under the rear deck lid where the Adblue tank is.
Thanks for the ebay leads... I guess I was not thorough enough...
Will send a pm to stickeygreen....
Thanks again.
I am in Seattle.
Thanks again.
https://mbworld.org/forums/gl-class-...-question.html
https://mbworld.org/forums/gl-class-...k-20-rims.html
https://mbworld.org/forums/gl-class-...tire-size.html
