---> CALI's hands-on ... STABLE CHASSIS VOLTAGE !!!
Old Jan 20, 2025 | 10:44 AM
  #251
W205C43PFL's Avatar
Originally Posted by streborx
I'm late joining this discussion, and I haven't thoroughly read and comprehended every post (some tangential to the OP topic), but has anyone verified that this single alternator wire is indeed a LIN bus? LIN bus connections are 3-wire -- power, ground and low speed bidirectional data -- that have LIN transceiver devices at each end to coordinate the exchange of data. This single wire is more characteristic of a quasi-static bi-level switch. Similar to a brake pad wear sensor that switches between ground and open. What exactly is being signaled to the ECU with this single wire that causes the reported behaviours?
BTW, I had my battery sensor disconnected for about 3 years to disable the start/stop function until I was able to kill it for good with my Launch scanner. The exuberance I experienced being rid of *** overwhelmed any sensation of improved engine or transmission performance, so unfortunately I have nothing to comment about regarding its impact.
If you haven't already, see this thread : ) https://mbworld.org/forums/e-class-w...tire-life.html
Old Jan 20, 2025 | 10:46 AM
  #252
W205C43PFL's Avatar
I see, pretty much confirmed it is not the same (at least not exactly) as the other forum members' cars.
That is the confusing part, if it was just like other forum members' I would know how to approach it, if it looks exactly like the CPS connectors, I would had been able to do it easily as I am familiar with that, I unplugged the oil pump solenoid sensor from the top. This one on the other hand is confusing.
Old Jan 20, 2025 | 10:47 AM
  #253
W205C43PFL's Avatar
It also certainly doesn't help that the rear of the sensor is facing the back side of the engine, if I can at least see how it looks like, I might had been able to successfully do it.
Old Jan 20, 2025 | 11:07 AM
  #254
Manny_c450's Avatar
C450
No need to see this connector, moreso by feel, notch is definitely there. Unfortunately only way would be to jack it up and do from bottom.. which is annoying in this Ontario cold. Fingers may be too weak to pull this thing off that is why a screwdriver wedged in between will loosen it up from bottom in my case atleast..
Old Jan 20, 2025 | 01:13 PM
  #255
JettaRed's Avatar
Veteran: Army
Not really sure what the signal is, but here is the schematic. You will get a DTC, but not a CEL.
Old Jan 20, 2025 | 01:48 PM
  #256
W205C43PFL's Avatar
Thanks for your reply. Reason why I need to see it so I know which side to push and then pull, I pushed from top to bottom and no success, I need to know which part of it is part of the connector and which part is the alternator, because if I am pushing and pulling the connector while holding on the alternator as well, that might explain why I was unsuccessful. Like the notch, how wide, how tall is it, that sort of thing.
Old Jan 20, 2025 | 01:50 PM
  #257
W205C43PFL's Avatar
https://cimg9.ibsrv.net/gimg/www.mbw...0f256894c2.png
https://cimg1.ibsrv.net/gimg/www.mbw...4cb47b20df.png
I can't believe I am saying this, but I want this trouble code
Old Jan 20, 2025 | 01:53 PM
  #258
W205C43PFL's Avatar
Matter of fact I even tried using the ziptie as leverage and just pulling that still wouldn't budge. I did hear squeaky plastics though : )
Old Jan 20, 2025 | 02:30 PM
  #259
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
FORWARD PROGRESS
We see there are multiple style of ALT-LIN connectors: on the side, on the back, with strain relief or without...
I am sure someone will eventually come across an entirely different setup. Every year model, chassis and engine brings differences.
We can only hope better ECU were made compatible with variable [12.6V to 14.9V] voltage without factory laggy engines/tranny throttle (**)
Thus you should confirm the issues you want fixed before experimenting.
Old basic LIN Bus is as described everywhere. It is used to interface ECU with W212 ALT such that voltage regulation is remotely controlled by the ECU. The bus itself works really well. What's done with ALT control calls for reliable engineering.
> What Does Not Work Well :
-1- the engine multi-shot GDI ignition under variable voltage causing limited driveability (**).
-2- the R-SAM CAN signaling to F-SAM>CGW>ECU that leads to deep drained by driving below 12v/11v and complimentary X-MasTree and LimpMode. The lack of failsafe voltage is dangerous.
Experimenting with automotive settings is not for everyone. An easy step is using a CTEK Battery tender or equivalent to help with stock battery drain.
(**) TASKFORCE GDI IGNITION TIMINGS:
Identifying the source of timing chaos calls for further fixing.
It's unfavorable to ignore side effects of this roller coaster.
We found the stock engine operating under touchy conditions.
Anything that affect timings impacts driveability performance.​​ My engine now runs vibration free under load with even contributions.
Factors are ...:
  1. pistons oiling
  2. variable voltage << - !!! -
  3. (gasoline grade)
  4. coils specs << - ! -
  5. spark-plug under gapping << - ! -
  6. harness impedance << - !!! -
  7. cyl. compressions
  8. cyl. temperatures
  9. CAN-C timings << - ! -
  10. ECU Lambda fuel map
  11. TCU auto adaptations.
The chassis is proven to works better given stable operational timings.
Old Jan 20, 2025 | 03:28 PM
  #260
NO CAN'T DO...
you can NOT muscle this thing out!!
Focus on OPERATING THE LATCH
PLAN B: save time with 5mn surgery at ECU CON-M
Don't let that piece of plastic stop you.
Old Jan 20, 2025 | 03:31 PM
  #261
PERFORMANCE TOGGLE SW
Install a CON-M toggle switch for when you can't have active ECU faults: ON/OFF
toggle sw including pigtails
Old Jan 20, 2025 | 03:41 PM
  #262
GND HAS TO BE RELIABLE
Not really sure what the signal is... but here is the schematic.
Thank you JR!
There's nothing better than a schematic to frame things clearly.
LIN bus signaling is referenced to "common GND" meaning it needs a glitch-free GND to flow data with minimal glitches overhead.
So clean the painted posts + double-up the salty GND strap.
Old Jan 20, 2025 | 07:22 PM
  #263
W205C43PFL's Avatar
Thanks for the advice, but I am worried about messing up and short circuiting and frying something, I will stick with the very traditional: which is unplugging.
Old Jan 20, 2025 | 07:24 PM
  #264
W205C43PFL's Avatar
Speaking of unplugging, another day of unsuccessful. I went ahead and ordered a set of pick tools, do you think it will help? It has 45, 90 and 180 degrees. If it does help, how should I use it?
Old Jan 20, 2025 | 07:26 PM
  #265
W205C43PFL's Avatar
https://cimg2.ibsrv.net/gimg/www.mbw...a8cc8ba057.jpg
I guess I am in for a glutton for punishment. I also want a constant trouble U012087, I need to make sure every day I scan it, it is there.
Old Jan 20, 2025 | 07:27 PM
  #266
W205C43PFL's Avatar
As in how should I use the tool to my advantage, how should I point and rotate?
Old Jan 20, 2025 | 08:25 PM
  #267
JettaRed's Avatar
Veteran: Army
Why does this remind me of a lock-picking video I watched on YouTube? (Sorry! Not trying to be mean.)
Just to be clear, have you gotten under the car yet? That may be your only option. My alternator sits right above the steering rack, if that helps to locate it. Yours may be different, though.
Old Jan 20, 2025 | 08:52 PM
  #268
streborx's Avatar
Top Answer: 1
G550
267 posts and I still haven't a clue what you all are talking about other than trying to find a connector and disconnect it.
Old Jan 20, 2025 | 09:05 PM
  #269
W205C43PFL's Avatar
All good : ) no problem, you are talking about the lockpickinglawyer right? I heard that one too, anyways here are the tools I bought:
https://m.media-amazon.com/images/I/..._QL70_ML2_.jpg
no : ( I can't go under the car yet, might need a few weeks to a month or two. I might need postpone this if it doesn't work.
Old Jan 20, 2025 | 09:06 PM
  #270
PLASTIC LATCH ...
I can not recommend to pick blindly with a tool. Picking requires line of sight to see what you are doing. Holding a flashight + mirror while picking the connector... that I cant do!
Besides sliding the latch is only the first step.
Next you'll need to squeeze, that's a job for pliers
tinny plastic parts are brittle, handle gently !!
All in all it took me less than 30mm including airbox removal and re-install. I even remembered to capture a finished view.
  #271
W205C43PFL's Avatar
The main post that should matter is the original post by forum member CaliBenzDriver, yes the rest is the discussion on this but what you need to read is really the original post of this thread. If you are not interested in the mod, that is perfectly fine. Sorry if I wasted your time.
Old Jan 20, 2025 | 09:08 PM
  #272
W205C43PFL's Avatar
I can not recommend to pick blindly with a tool. Picking requires line of sight to see what you are doing. Holding a flashight + mirror while picking the connector that I cant do!
next you'll need to squeeze, that's a job for pliers
All in all it took me less than 30mm including airbox removal and install. I even remembered to take couple pics.
I will need to postpone this project until later then, thanks for the help these days, all the best to others who is doing this mod and hope all can enjoy it, I will be missing out now.
Old Jan 20, 2025 | 10:27 PM
  #273
JettaRed's Avatar
Veteran: Army
Yep, that's about it. I know it sounds crazy, but it works. My car's shifting is becoming smoother every day. The throttle response seems quicker, as well.
None of these "mods" is going to produce changes like a turbo tune with a 35% bump in output, but they do make subtle, yet noticeable changes in how the car drives. The problem is, we grow accustomed to these changes so quickly you begin to think the car is now driving normally.
Here's the thing, any of these mods is completely reversible. Just plug the wire back in.
Old Jan 21, 2025 | 11:06 AM
  #274
W205C43PFL's Avatar
Time to question life... What was I doing this whole week from the top?
Only problem is now my back is seriously hurting might had pulled a muscle, took me less than a minute to unplug it underneath. There is no clip like forum member Manny_c450 mentioned and the flat head screw driver push and wiggle did it.
Happy to say ALT-LIN on my car is successfully defeated!
Can't test it out yet as can't drive today due to back pain but look forward to it.
Thank you all of you who helped me!
Old Jan 21, 2025 | 11:30 AM
  #275
JettaRed's Avatar
Veteran: Army
Woohoo! Rest your back. And don't tell your wife (or whoever you answer to) you hurt it working on the car -- no need to make things worse.
