What is this Motorola module? (pic inside)
"The Communication Platform module for the telephone package contains the PSE box supporting the software and associated electronics for the integration of the handset to the vehicle. The CP module also contains the Tele-Aid module supporting the emergency notification system in the vehicle."
It's the 2004 V60s version.
http://phdwebsite.powerpulse.cc/V60i...ual%20v4.6.pdf
All kinds of good Motorola stuff at
http://phdwebsite.powerpulse.cc/V60i%20Documents/
as I'm sure Skylaw knows.
I have the V60i phone laying around somewhere... so all I need is the V60i cradle to connect it and make it work?
http://cgi.ebay.ca/OEM-Mercedes-Moto...2em118Q2el1247
I think I'm going to get that cradle and hook it up with a blue tooth module that's probably the best route?
VCS is cool but not necessary. But I thought it was normally installed at the same time as the PSE. Do you have the cradle holder installed?
2005 S500 4-Matic, 1978 450SL
Whoover is correct in what he has advised you. With the proper V60S cradle (which has FAKRA connectors needed for your car's console), you can use either a Bluetooth plug-in phone (a V60S or perhaps even a V600, if you want a carrier other than Verizon). Alternatively, your Bluetooth solution for the '04 is the "puck with tail."
Not to highjack the thread (and sorry for possibly stupid question), but is there an easy way to see if the car is pre-wired for V60? I have 2004 S500, and don't see any plugs in the compartment...
That probably means it's not wired. It was like $1,000 as a factory option and $1,500 as a dealer install so most cars didn't get it. The clues that it was installed are usually the cradle, or at least signs of wiring in the center console and the VCS stalk.
Once you install the console equipment, all you need to do is have your dealer activate your system - it's called "version coding." Then. you're in business for cell. However, you will not have Tele-Aid. The CP-211 has an analog Tele-Aid system, and analog service in no longer available in the U.S. If you want Tele-Aid, you'd have to do a digital system upgrade. It is not necessary to have Tele-Aid in order to activate your cell phone.
Voice control is a nice option, but is not required for the phone system.
See https://mbworld.org/forums/showthrea...77#post2788377, particularly post #5; and the phone bulletin for your car at http://home.earthlink.net/~phdwebsit..._bulletins.htm for the locations of the connectors in the console.
If you go to a plug-in phone, you will need the linear compensator shown in the bulletin; if you go to Bluetooth, you can omit it.
Thanks, Skylaw! So, if I go Bluetooth, it looks like I have the following options:
1. Expensive (?):
S-Class vehicle completer kit: B Q 682 0878
1 Voice Control System, control module (MOST): B Q 682 0881
1 Standard install hardware kit: B Q 682 0462
1 Bracket, linear compensator: B Q 682 0427
1 PTT stalk: B Q 682 0820
1 Linear compensator:B Q 682 0829
1 Manual, Voice Control (SJJN 5661A): P-2780-04A
V60 cradle short-cord kit (MOST, FAKRA): B Q 682 0882
1 V60 cradle with short coil-cord: B Q 682 0883
1 V60 holder: B Q 682 0768
1 Battery insert: B Q 682 0832
1 In-vehicle manual (SJJN 4769A): P-2798-03A
2. Less Expensive:
Do I need the PTT stalk?
Finally, I would want the system to be programed, and I would need to buy the Bluetooh Puck.
Is this correct?
Thanks a lot in advance,
eugeneflim
1. Expensive (?):
2. Less Expensive:
Is this correct?
eugeneflim
Regarding the first option, as I said in my prior post, if you go to a Bluetooth configuration, you do not need the linear compensator (or its bracket) at all (and, the compensators are hard to come by). If you want to use a V60S phone CDMA, Verizon only) or a V600 (GSM, everyone else), you will need the linear compensator and bracket, and you will need the V60 cradle and holder, and the possibly the battery insert.
Installing voice control is not mandatory in any of the options, and if you omit the voce control module, you can also omit the stalk. If you want voice control for the phone, radio, CD and and CDC, you need both. The Voice Control has a Help menu that would let you get by without the manual, as well.
In both the first and second option, you might talk to your dealer about how much of the V60 cradle and holder you need when you use the Puck With Tail; I have never physically seen one installed in the '04, so haven't seen how much is used between the V60 cradle and the V60 phone holder. AWS would be an alternate source of the information. Having that discussion might keep you from buying parts you don't need. You would not need the "battery insert" with the puck.
And yes, definitely you will need version coding - usually around $85, unless the dealer installs for you.
Oh, I think I am starting to understand this! Since I only need Bluetooth, and don't care about voice control, it appears all I need is this:
1 MERCEDES-BENZ V60 BLUETOOTH CRADLE ADAPTER: B6 787 5855
The only question remains is whether I need the cradle/insert thingie. I guess, will talk to AWS and see what they say...
Thanks!
Thanks!
And, I've done even more research, and it looks like I only need the puck! This is because I don't need the voice control (hopefully, I am correct here). Just get it connected inside the cener console, and activate via Star computer.
And, you're right - the cars with the CP-211 electronics need only to connect the equipment in the console, and have the system activated through version coding (with STAR).
Thanks - that's exactly what I will do. I do know that folks have done this activation, but I do not have any feedback on the cradle/puck questions. Will look forward to yours.
Tusabes, read the How-To Guide sticky to determine what you need for fully integrated Bluetooth in a '00 S-Class. Yes, the V60 puck will work (it's your only MB option) - but you may have other things to do.
Cheapest might be use of a 3rd party kit that does not integrate with COMAND and garbage up the appearance of your car. I haven't researched them, and can make no recommendations. Zam2000 recently did a 3rd party add-on that didn't look too bad, and it integrates - see https://mbworld.org/forums/s-class-w...ee-system.html. His car seems to be an '03, which would use a D2B fiber optics bus as yours does.
Parrot Systems offers a range of add-ons, some of which offer no phone book download - they just let you make calls using Bluetooth. Other Parrot systems offer more. Google them.
