Indi oil change and cracked the oil pan?
I have a strict rule with shops: You break it, you bought it. This guy should have gotten the torch out and heated it, rather than just applying more pressure until the whole thing broke. It's pretty clearly his fault...
Unless, he gave him the "ok" to try....hmmm?
This guy is a professional mechanic, and he knows better. This kind of outcome is unacceptable. Ideally, he should cover the entire job for free, but if the economy's tight for him, then he should at the VERY least offer to pay at least something towards the part and give the labor on the replacement for free.
My indi has agreed to labor for free since he was turning the wrench so, although I am not happy I am "only" out $408. I figure it is better than if I had been at the stealer, they would have likely done the same thing and then would have tried some BS story about how when they dropped the cover, they found a big mess, and charged me a gazillion! However, it does SUCk!
Oh well, the good news is that I have not had the car for some many days, all I want is my beast back -- 75 degress and sunny here in TN! Thanks to all -- just needed a sanity check!
I think you should tell him you're unsatisfied and he should pay for the new oil pan and labor.
Reminds me of the time my Harmonic Balancer went out and cracked my upper oil pan. $800 I think with labor so its probably a similar job.
Sorry to hear about your luck.....we have all been there
The drain plug at the front of your E 63 AMG engine is not convenient for draining the oil. Following the service instructions on the E 63 AMG, only the drain plug in the oil pan at the back of the engine is appropriate for draining the oil. Extracting through the dip stick is not possible either. A nearly complete emptying is guaranteed while your engine is at operating state temperature. A possible remaining quantity in the front area is negligible.
We hope this information finds you helpful.
Best regards,
AMG Private Lounge Team
good luck
