Old Jun 17, 2015, 07:21 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Steering and Suspension Guides
Print Wikipost
W211 KW Coilover Swap Part 3
Rating: Thread Rating: 10 votes, 4.90 average.
Old Jun 20, 2012 | 06:58 PM
  #251
Htownbrother's Avatar
'14 Mustang GT, '13 F-150 SuperCrew EcoBoost, '05 SRT4, '04 E55 AMG
Originally Posted by Benz Works
Email sent.
Old Jun 20, 2012 | 07:35 PM
  #252
spinn's Avatar
2004 E500
Originally Posted by chipnpulley211
I am interested in converting my 55 to coilovers please send me a pricing on all the parts that are needed for this conversion.. 2003 E55.. Thank you very much I appreciate it.
Best to take some time and read through the whole thread. I post the modified parts list at post #228.
Old Jun 22, 2012 | 07:40 PM
  #253
SamBoler's Avatar
W211 E55
Best modification so far!! Car goes in the direction you want it to now much better
Old Jun 23, 2012 | 09:03 AM
  #254
vettdvr's Avatar
03 E500 and Corvette
Let me now see if I understand, the coil overs are much better than the air suspension. On this site people have been taunting how great the air suspension is and it is way advanced and better for the car and now coil overs are better?
Wish mine had coilovers from day 1.
Old Jun 23, 2012 | 09:13 AM
  #255
FASN8N's Avatar
CTSV/6sp Grocery Getter
You must have been reading a different site about a different car? I can't recall anyone ever raving about the air suspension on these cars the only benefit to air suspension is that you can raise/lower the car electronically
Old Jun 23, 2012 | 09:18 AM
  #256
vettdvr's Avatar
IT was this site but under w211 and raise/lower is just an expensive do da that adds expense at the cost of reliability.
Old Jun 23, 2012 | 03:18 PM
  #257
SamBoler's Avatar
W211 E55
The handling characteristics of air suspension is terrible.
The only way someone would say it's good is if they never took a turn "aggressively". Maybe they like the ride comfort?
Old Jun 23, 2012 | 03:31 PM
  #258
cij911's Avatar
one car at a time
Terrible - no way. Post some track times (road course) and show me a 5+ second improvement.
I think the air suspension is nice for a luxury cruiser, but I also think each design has its purpose.
All this said, I am sure I would consider going this route if I was looking at some major $$ suspension repair bills.
Old Jul 9, 2012 | 02:08 PM
  #259
spinn's Avatar
2004 E500
if anyone in SF Bay Area is planning to install some KW V2 coilovers (already purchased) on their W211, please get in touch with me. Looking to fabricate a rear shim to give it some extra clearance (to avoid alignment issues), but need the loose rear spring perch to vacuum-form a copy. Don't want to go through removing mine at this time.
Old Jul 9, 2012 | 02:43 PM
  #260
Peter_02AMG's Avatar
07E63, 12E350, 08997TT, 16SiennaSE
Originally Posted by spinn
if anyone in SF Bay Area is planning to install some KW V2 (already purchased) on their W211, please get in touch with me. Looking to fabricate a rear shim to give it some extra clearance (to avoid alignment issues), but need the loose spring perch to vacuum-form a copy. Don't want to go through removing mine at this time.
what does this perch look like? I might have extra.
Old Jul 9, 2012 | 02:54 PM
  #261
spinn's Avatar
2004 E500
I doubt you'd have an extra...it's the part that sits between the chassis and the coil. It is the perch and adjustment cylinder piece in the kit.
Old Jul 9, 2012 | 04:31 PM
  #262
infantry's Avatar
07 E63. 07 STi limited #606/800
Like a camber plate?
Old Jul 9, 2012 | 04:40 PM
  #263
spinn's Avatar
2004 E500
Not really...it's to hold the rear springs.
It's the black piece in the photo. That holds the spring within the lower control arm and it's compressed against the chassis.
Looking to 'borrow' one without having to disassemble my setup.
Old Jul 9, 2012 | 05:06 PM
  #264
timeToy's Avatar
'08 E63 Wagon
What kind of alignment issues did you experience ? Is it related to the coilover swap or to the "new" ride height ?
Old Jul 9, 2012 | 05:37 PM
  #265
spinn's Avatar
2004 E500
one is a result of the other, so yes to both, the coilover swap lowered my ride height. You can check out my Alignment check results. Whether it's really that bad is debatable. I would like to not have to buy a camber kit for the rear, as I think it could be adjusted a little more if there was a shim available for the spring perch. The KV V2's don't allow stock ride height and the minimum setting is 1.2" lower than stock; I'd like to be only about 0.8" lower.
Old Jul 10, 2012 | 01:08 PM
  #266
That not it than. i got something like this.
Old Jul 10, 2012 | 02:28 PM
  #267
spinn's Avatar
2004 E500
Is that what was part of that KW tool kit? My kit didn't come with the tool kit. Is there a part# for it (just to see what it's for)?
The discs in front...what are they made of? Can you provide some dimensions and a side view of it? That may be what I need. The Mercedes shims/perches can't be used with the KW system, due to the need for the adjusting cylinder. Thanks!
Old Jul 11, 2012 | 03:28 AM
  #268
Bimbis's Avatar
Serge, kindly pm me the parts list. i'm seriously considering swapping out for my E320. Do you have a pic of the finished product? i'm not looking for a ride lowering kit. i just want to be rid of the airmatic system but with the same ride height maintained when i'm done. thanks.
Old Jul 11, 2012 | 06:49 PM
  #269
spinn's Avatar
2004 E500
Attachment 239565
Thanks for the info Peter! That looks like it will solve my dilemma.
Old Jul 11, 2012 | 06:52 PM
  #270
spinn's Avatar
2004 E500
What you want to do is simply buy the stock shocks and springs for a non-airmatic E320 system if you don't want to be lowered. Install is relatively straightforward, provided you have someone that is knowledgeable in removing the airmatic components properly.
Old Jul 17, 2012 | 04:36 AM
  #271
christiandel11's Avatar
Mercedes E55 AMG
Hey guys,
Airmatic has officially failed in my E55... I'm looking at doing either D2 or Kspot coilovers now... Any thoughts? Any additional parts I'll need in addition to the ones provided in the kit?
Thanks a lot!
http://www.ebay.com/itm/Ksport-Kontr...vxp=mtr&_uhb=1
http://www.ebay.com/itm/D2-Racing-RS...ht_1769wt_1189
Old Jul 17, 2012 | 04:42 AM
  #272
Originally Posted by christiandel11
Hey guys,
Thanks a lot!
I bought the ksports from vividracing in Arizona. I haven't installed them yet but there's a pdf files I believe in this thread with all the additional parts. Serge keeps them in stock ready to ship.
I'm getting my ksports installed as soon as I get back from vacation....praying the airmatic holds up to get it all done.
Old Jul 17, 2012 | 10:15 AM
  #273
spinn's Avatar
2004 E500
Hey guys,
Thanks a lot!
jump to post#228. For the Ksport or D2, you might not need the stock top mount for the front coilovers as it might already be included in your coilover package...verify if you do...the KV V2's do not come with them.
Old Jul 17, 2012 | 10:17 AM
  #274
spinn's Avatar
2004 E500
Post photos of the Ksport package prior to install...just to see what's actually included, so we can see whether certain parts aren't needed. Thx.
Old Jul 17, 2012 | 12:40 PM
  #275
Mercedes E55 AMG
Thanks Spinn. I just called the D2 guys, they said all I'll need to swap them out is the rear lower control arms, and when I called the Ksport guys they said I won't need ANYTHING, they say the kit comes with everything I'll need for the install... Not sure if they know what they're talking about after looking through this thread...
You have already rated this thread Rating: Thread Rating: 10 votes, 4.90 average.
