Bi-X: W203/CL203 OEM Bi-XENON Upgrade, Auto-Levelling & Programming thread
Old Dec 14, 2007 | 09:21 PM
  #1926
yeuchau's Avatar
Stage 2 C7 A6, QX60
reprogram doesn't take more than 5 mins to do it
Old Dec 15, 2007 | 12:05 PM
  #1927
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Originally Posted by kevincao
LOL so true...only a few hours later my lights start to flicker and error messages appeared!
the threshold of failure came very fast but i when by the MB stealer and paid $70 to program (1/2 hr work)...
Thats not bad. At least they didn't give some lame excuse and refuse to do it.
Mostly places want an hour just to hook it up.
Old Dec 15, 2007 | 05:01 PM
  #1928
Buellwinkle's Avatar
Half hour labor is fair as many won't do it at all. If you were in for an A/B service they would probably do it for free but just bringing it in for that reason, they probably have minimum labor charges.
Old Dec 17, 2007 | 12:07 AM
  #1929
roro's Avatar
2001 C320
What is the difference between US spec and Euro spec, and how do I get in touch with Steve?
Old Dec 17, 2007 | 12:39 PM
  #1930
Be careful with euro spec, maybe UK RHD spec and have a wrong pattern and blind people here. Also, U.S. have DOT certification so it's legal. Steve is at www.mbenznl.com
Old Jan 7, 2008 | 09:46 PM
  #1931
linkmustang's Avatar
'03 Coupe won't do Bi-Xenon conversion, what is needed to make it happen on my car?
03 coupe wont to do the bi xeon coverion what is all need to make it happen on my carit a 03 coupe with the **** light in it now want the clear housing and the bi seons what is all need
Old Jan 7, 2008 | 10:30 PM
  #1932
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
Hello C230 617, biatch, or whoever you are.
Bye Troll.
Old Jan 7, 2008 | 10:32 PM
  #1933
BlackLiquorish8's Avatar
C3Twon AWD Jumpofffff
your really bad at spelling first off i'm having trouble trying to understand what your asking... anyways i'm guessing you want clear bix in your coupe??? they are rare to come by just keep checking ebay or you can order them on some german website
Old Jan 7, 2008 | 11:45 PM
  #1934
advans's Avatar
C55 ///AMG, 535xi
is that link mustang jeff?
Old Jan 8, 2008 | 12:01 AM
  #1935
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Bye Troll.
Ouch.
Remind me to engage any remaining grey matter before submitting ‘tard questions on this forum!
Old Jan 8, 2008 | 02:25 AM
  #1936
smpkd bef bong keat ot wets geed....do ude
Old Jan 8, 2008 | 06:42 PM
  #1937
yess sorrry about that ok i have 03 c230 non sport the coupe i want the bixoens for it so any of you have the part numbers for them right and left side and if i get them what all is need to install them
Old Jan 8, 2008 | 06:53 PM
  #1938
infected's Avatar
2007 ML500
Not sure if this is it but here you go: https://mbworld.org/forums/showthrea...=1#post2273509
Old Feb 3, 2008 | 03:04 PM
  #1939
DmitryS500's Avatar
'05 C230 coupe auto
Bi-Xenon lamps installation on Coupe! Help
I have a small problem. Well it's not really a problem.
My car (2005 Coupe) didn't come with Bi-Xenon lamps originally, however, I went ahead and bought them. The installation by itself is relatively easy, however, I know the computer needs to be reprogrammed.
Is it possible to do ONLY at the dealer or some experienced shop can do it. If it's the case, can you recommend any shops in NYC? If not, would any dealer do that reprogramming? How much would it cost?
And last question, would that void my warranty? I hope not since the parts ar OEM (used though)
Thank you all for the input
Old Feb 3, 2008 | 03:12 PM
  #1940
KIRA's Avatar
2002 C230 coupe , NOt THE AVATAR!!
forum searching and DIY has your answer
Old Feb 3, 2008 | 03:42 PM
  #1941
SeaCoupe's Avatar
You have caught me in a good mood, and feeling generous so:
You need a DAS machine to program you settings to Xenon Present. As Brabus was saying, there is a thread somewhere in here with the pics of the screen needed to put the correct setting in. It is a good idea to have when you get it set, because a tech may tell you they don't know how.
Some independent shops have the DAS. Look for specialized Mercedes repair places. You may have a tough time getting a dealer to do the work. I was told no by three different dealers after putting in my Bix.
Good luck, post pics.
E
Old Feb 3, 2008 | 04:02 PM
  #1942
DAS, also known as "Star diagnostic System"
Ask your indie shop if he has the system.
And yeh, find those screen shots, or at least the sequence to set.
Did you get the set on ebay that sold yesterday?
Old Feb 28, 2008 | 12:33 AM
  #1943
alim ulama's Avatar
'00 C240 W203
hey guys.. sorry to bump an old thread.
I already got a hold of my Bi-Xenon for about 4 years or so, but little do I know about the terminology of Bi-Xenon on W203. Does a Bi-Xenon Projector means that the hi-beam and lo-beam came out from 1 projector?
cause I noticed that my Projector only beam the lo-beam, but the hi-beam came from the inner lamp (not the projector).
and I also noticed that when I do hi-beam, there is a sound like 'click or tuck' on my headlamps.
thanks a lot for any help, mind my bad English write up
Old Feb 28, 2008 | 12:59 AM
  #1944
e1000's Avatar
a quarter mile at a time
yes you have the bi-xenon setup. For Bi-Xenons, the inner high-beam lams turn on AND the shields on the low beams move to allow more light out of the low beam HID lams at the same time. That is the click sound you are hearing.
Old Feb 28, 2008 | 01:00 AM
  #1945
e1000's Avatar
and just for the record, the W203 US Spec Bi-Xenons use the same BOSCH projectors as the E46 3-Series BMW's did, all the way up to the M3.
Old Feb 28, 2008 | 01:01 AM
  #1946
raymond g-'s Avatar
99 E320
see if this helps....
p.s. yes, I have some degree of yellowish blob at the apex of
the horiz and base of the rise. it is indeed caused by refraction
at the focal point...in this case, the cutoff shield right below the
yellow blob
Old Feb 28, 2008 | 02:57 AM
  #1947
alim ulama's Avatar
'00 C240 W203
Wow.. thanks a lot for the illustration, now I noticed when I do my Hi-Beam the inner lamp flashes the light and the projector is brighter also.
great info guys, again sorry for the noobs question..
Old Mar 7, 2008 | 01:13 AM
  #1948
MBAsian0000's Avatar
GLK350 4Matic
anyone selling OEM Bi-xenon headlights?
Im looking to buy a pair of OEM bi-xenons to replace my oem 06 clear headlights.
I believe steve is selling for 1350. but i'm looking to save some money. so if anyone is selling theirs please let me know the price.
and by the way can anyone offer advice on the whole installation process and who to look for to install the oem bi-xenons. Do i bring it to the dealerships?
thanks.
Old Mar 7, 2008 | 02:13 AM
  #1949
coin's Avatar
'06 CLK500
thanks.
PM'd
Old Mar 7, 2008 | 02:24 AM
  #1950
spyderpig's Avatar
'02 CL203 M111
OH! how about the one for the coupe!
You have already rated this thread Rating: Thread Rating: 21 votes, 4.81 average.
