2019 C300 Base Audio Upgrade
Old Mar 1, 2022 | 10:50 PM
jacarbon's Avatar
2019 C300
Just got this car as a great deal, couldn't pass it up. Coming from an audiophile setup previously. From what I gather, I'm going to be extremely disappointed with what the 2019 C300 base audio comes with, and limited in options moving forward.
there are 4 door speakers, no tweeters (not even an option to set them up in the pillars?), and a "woofer" under the dash? Is there anything else?
What have you guys done previously to upgrade the sound besides adding a separate subbass woofer? That's easy and not what I'm here for.
4 inch speakers leave a lot to be desired from mid bass, has anyone retrofitted anything custom to get larger speakers into the doors? I've read about people using coaxials...
Probably shoving something to run middbass from the under dash woofer, upgrading the door fronts, and somehow getting tweeters with a 5 channel amplifier and DSP seems to be the way to go..thoughts?
Old Mar 2, 2022 | 03:38 PM
W205C43PFL's Avatar
Your car belongs to W205, so you might get more replies if you post in that sub-forum: https://mbworld.org/forums/c-class-w205-186/
Not sure if these posts I found for you will help but I am posting them here anyways in case it does:
Here is a thread to start with (the thread is 20 pages long and began back in 2016, some links are no longer valid and some information might not be applicable for your facelift (https://mbworld.org/forums/c63-c63s-...ml#post8115146), try to read the more recent posts and go from there, you don't have Burmester so I guess your options could be retrofit Burmester or get a whole new aftermarket system altogether: https://mbworld.org/forums/c-class-w...ml#post7962453
Here is a thread talking about how to add a subwoofer (again it is for a Burmester system)
https://mbworld.org/forums/c-class-w...er-system.html
Here is an aftermarket setup:
https://mbworld.org/forums/c-class-w...lass-w205.html
and another aftermarket setup (it is on a facelift vehicle so should be applicable to your vehicle):
https://mbworld.org/forums/c63-c63s-...stem-done.html
yet another aftermarket setup (but it yet again has Burmester to begin with):
https://mbworld.org/forums/c-class-w...-jl-audio.html
YAAS (yet another aftermarket setup): https://mbworld.org/forums/c-class-w...pic-heavy.html
Here is an interesting thread about Burmester:
https://mbworld.org/forums/c-class-w...ml#post6766672
The Burmester ones might not be applicable to you but it should give you a general idea of what to expect.
More info (comparison) on both the FrontBass and Burmester setup:
https://mbworld.org/forums/c-class-w...subwoofer.html
I came across this, the upgrade applies to the facelift and specifically for the W205's audio system so it should work well for you I hope:
https://mbworld.org/forums/c-class-w...ispreloading=1
