Transmission/shifting question
Old Jul 14, 2010 | 01:51 PM
riverace's Avatar
2006 C55 AMG
I've done a lot of reading on this "jerk" problem and I wanted to confirm it was in fact my issue. Mainly because from what I've read it seems to be a C32 issue.
For me in second and first gear the shifting comes in late or in other words very evident, its slow or abrupt. When down shifting from 3-2 or 2-1 it really slams into gear and is a hard shift. When cruising around a parking lot in second gear or first at times it "bucks" if I hit the gas at low speed an let off you're going to lurch forward or get "bucked".
Is this consistent in C55's with "the jerk". I just took it to the dealer and found no issues with the transmission (surprising I know). Im working with RBM North of Atlanta, they originally said it was a MAF problem and replaced the MAF, still same issue. I will admit I had green filters and because of this it was not covered under warranty as the service manager claimed the filters passed oil and helped destroy the MAF, I thought this repair would fix my issue and the service manager was pretty confident it was the issue. That's another thread...
Any advice on my issue, its pretty annoying to be quite honest.
Old Jul 14, 2010 | 09:24 PM
Popo's Avatar
2007 GL450 2005 C55 2002 C32 sold 2001 ML320 sold
I had a similar "jerk" on my 2002 C32 (no mods whatsoever). It was noticeable but mild, and i put it down to the operation of the lockup clutch as described on some of the forums. I had tried replacing the transmission fluid (OEM stuff only) and resetting the computer which helped somewhat, but it was never completely smooth. This was supposed to be normal. Driving aggressively made the "jerks" unnoticeable...but you do feel the gear changes.
My current 2005 C55 has no such jerk in any gear and shifts more like a usual Benz.
Old Jul 15, 2010 | 09:59 AM
riverace's Avatar
2006 C55 AMG
I guess I'm taking it back in, some days its more noticeable than others, but its enough of a big deal that I can tell its there.
Old Jul 15, 2010 | 10:31 AM
loudandheard's Avatar
C32/C55 AMG
If you're vehicle is still under warranty, then definitely go back, but if you're paying out of pocket you need to to do a bit more research.
If I remember correctly the issue is very common in the C32's, but not so much on the C55's. A lot of people point out that the TCU software needs to be upgraded and this will solve the problem, but there are various TCU's and the only ones that could be upgraded were the ones from 2004+, so you're should be able to be upgraded. I also heard that upgrading to blue top transmission things, can't remember the name right now, helps as well, but I thought the C55 may have come with them. I might be wrong on that last part.
Here are a few threads for reference:
https://mbworld.org/forums/c32-amg-c...slip-jerk.html
https://mbworld.org/forums/c32-amg-c...bout-jerk.html
https://mbworld.org/forums/c32-amg-c...hirp-saga.html
https://mbworld.org/forums/c32-amg-c...g-strange.html
https://mbworld.org/forums/c32-amg-c...-2800-rpm.html
https://mbworld.org/forums/c32-amg-c...g-c32-amg.html
https://mbworld.org/forums/c32-amg-c...any-ideas.html
https://mbworld.org/forums/c32-amg-c...-rpm-jerk.html
https://mbworld.org/forums/c32-amg-c...d-finally.html
Old Jul 16, 2010 | 02:26 PM
spr's Avatar
spr
I had this problem. I changed the fluid and filter with latest MB 7 speed with better friction modifiers same problem. They replaced my torque converter and all good. I also think it really has to do with proper ring gear adaption. I only had the problem with the car cold. it would jerk at 1500 in 1st or 2nd irrespective of M or S mode.
Old Jul 16, 2010 | 02:41 PM
omagicbum's Avatar
C55
It is not a C32 only isssue, I had this on my C55. It was a TCU problem. The tcu was wicking oil and the connectors got fouled. Replaced the TCU, still had the problems and the dealer said it was low on transmission fluid. What I don't understand it was only a week later. But replaced the TCU again, refilled the fluid and now I have no problems.
Hope that helps.
Old Sep 25, 2010 | 11:14 AM
riverace's Avatar
2006 C55 AMG
I have an embarrasing update to this...
When I took my car in to get the B service, I had them take a look at the issue with the erratic shifting. The mechanic took it out for a drive and he immediately checked the transmission level. It was one quart low... It drives perfect now!
Why didnt RBM North of Atlanta find this and instead I wasted my time there...
Ill be going to "My Mercedes & Bimmer Place" in Cumming from now on, fantastic service and the mechanic Scott knows what hes talking about.
Old Sep 25, 2010 | 05:32 PM
SteveoAMG's Avatar
From: Manhattan upper eastide, New York City moved back to south florida currently
MooseJaws 04 C32
my car Also does this sometimes it's a common error on c32s
