C450/C43 AMG
C450/C43 Wheel Fitment Guide
Old Feb 19, 2020 | 06:17 PM
  #551
CClement's Avatar
2009 C230
I run 19" x 8.5 +40, 245/35/19 Front, 255/35/19 Rear with 10mm spacers all around.
Perfect if you ask me. See attached. BTW, I even run 265 for winters in the rear without problem. (I had a set
from a previous vehicle so that's why I use them).
Old Feb 19, 2020 | 08:33 PM
  #552
Abe94's Avatar
2019 Mercedes C43
Originally Posted by djrabbi
My wheels are for sale if anyone wants
what wheels do you have. Message me details and pics.
Old Feb 19, 2020 | 08:38 PM
  #553
djrabbi's Avatar
EQS AMG, E53 AMG, GLE63s
Got new wheels on. Pokes out a bit but overall happy with set up.
Here you go
Old Feb 20, 2020 | 07:53 AM
  #554
alexasa's Avatar
c
Originally Posted by Slpr
I'm thinking of getting a set of Rotiform BUC-M, the specs are 19x8.5 +45 all around, I understand that I will need spacers for the fronts and optional for the back depending how aggressive I want to go. My question is for the tires, should I do 245/35/19 all around or am I able to go with 245/35/19 fronts and 255/35/19 in the rears?
go squared - can rotate increasing longevity and will make the car more neutral in terms of handling.
unless you're tuned.
Old Feb 20, 2020 | 11:13 AM
  #555
Slpr's Avatar
C450
That sounds like a good idea! Thanks for your help!
Old Feb 21, 2020 | 12:53 PM
  #556
Mojorodt-23's Avatar
AMG C43 2017
Hi guys
I´ve been looking for rims that will surely fit, but it´s a jungle out there. Have tried to read most in this thread, but maybe not all. So, I had my C43 coupe at the local wheel dealer here in south Sweden and measured clearance with OEM 19" wheels. At rear its no probs both in and outside, could probably swallow 10" wide rims. But the front clearance with the very narrow OEM 7,5" is just 15mm inner from suspension strut and 11mm outside before sticking outside the fender. Means if you go up to 8,5" in front, they will stick out even with minimum clearance inside. I don´t want that. 8" is the most narrow aftermarket I can find, and it will be with ET30-35. My dealer found a very useful site to calculate how your new setup affects inwards and poke out: www.willtheyfit.com
//Magnus
Old Mar 3, 2020 | 11:54 PM
  #557
Bananamani's Avatar
2017 C43
Wooooah that was a lot of reading. So after 5 bent wheels and 1 cracked rim Ive decided to throw in the towel with these trash AMG wheels. I went ahead and ordered the Vorsteiner VFF-107 wheels
Front: 19 x 8.5 et 30
Rear: 19 x 9.5 et 46
Im currently running Michelin AS3+ stock sizes (225/40R19 & 255/35R19), My plan was to size up to 235/40 and 265/35, but unfortunately Michelin doesn't make the AS3+ in the 235/40 size. My options are to switch to different brand/model tires (which I do not want to do), Stick with the stock tire sizes or upsize to 245/35R19 and 275/30R19 (if it will fit), If I size up in width, I would have to size down is ratio, would this effect drivability?.Also which set up would look more visually appealing and are there any benefits/drawbacks from either tire set up? Thanks in advance gang.
Old Mar 4, 2020 | 12:34 AM
  #558
alexasa's Avatar
c
switch brands
Old Mar 10, 2020 | 06:19 PM
  #559
alexasa's Avatar
c
'mirin my fitment lol
Old Mar 10, 2020 | 07:46 PM
  #560
TModelle's Avatar
C190
Nice! What are your current wheel and tire specs?
Old Mar 11, 2020 | 08:43 AM
  #561
alexasa's Avatar
c
19x8et25 w/ 235/40/19
19x9.5et38 w/ 265/35/19
Old Mar 11, 2020 | 09:24 AM
  #562
TModelle's Avatar
C190
Truly awesome setup.
Based on what I’m looking at, my planned upgrade to 20x10.5ET52 is looking very promising.
Old Mar 11, 2020 | 09:44 AM
  #563
alexasa's Avatar
c
Truly awesome setup. Based on what I’m looking at, I’m starting to wonder if my planned upgrade to 20x10.5ET41 in the rear is going to work at all.
Thanks. Keep wanting to switch it up but never actually pull the trigger.
You need to be mid et50's for 10.5 in the rear.
Old Mar 11, 2020 | 10:28 AM
  #564
TModelle's Avatar
C190
I replied too fast without recalling properly. I referred to my notes and the ET I’ve planned is 52. I’ve edited my post.
Old Mar 11, 2020 | 10:30 AM
  #565
TModelle's Avatar
C190
I’m going to do C63 front fenders and am estimating the fronts to be 20x9ET24 on 245.
Old Mar 12, 2020 | 09:41 AM
  #566
Thinkie's Avatar
W211 E270
Ok I got 2016 C43 AMG Cabrio, lowered on H&R
Will this work:
20*8,5 ET32 235/35 PilotSport4
20*10 ET48 275/30 PilotSport4
Cheers!
Old Mar 13, 2020 | 02:10 PM
  #567
mo11's Avatar
2017 C43
Will this work:
Cheers!
Yes, it will. If you can spare a little and go with height adjustable springs, it’ll be better, specially on 20’s.
Old Mar 13, 2020 | 02:20 PM
  #568
mo11's Avatar
2017 C43
I plan to do the same 10.5” but, 19’s not 20’s. Let us know what ET you finally end up with. I wanna go et 55 or 57, because it’s easier to add a spacer if it gets too close to the inside of the wheel well, than close to the fender.
Old Mar 20, 2020 | 11:51 AM
  #569
belvius's Avatar
C43 AMG
So I was able to find some wheels with the following specs:
19x8.5 ET32
19x9.5 ET45
Going to be running 225/40/19 & 265/35/19. Will these fit without spacers at the front because of the +3 offset that the wheels? Currently on stock height and have no plans to lower it.
Old Mar 27, 2020 | 09:25 AM
  #570
AformerN63ownr's Avatar
C43
Two wheels by Vorsteiner in this fitment: 1. Vorsteiner V-FF 107 Carbon Graphite by Vorsteiner Wheels 2. Vorsteiner V-FF 103 Carbon Graphite by Vorsteiner Wheels
19x8.5 et35
19x9.5 et46
(verified that 19x8.5 et35 clear brake calipers in the V-FF 107)
Would you know if Vorsteiner VFF-112 with the same setup above fit a factory height C43?
Old Apr 6, 2020 | 01:53 PM
  #571
OverboostC43's Avatar
2018 GLC63 AMG
Anyone else trying to keep 18's for ride quality? One of my factory rims is cracked and I need to get it repaired or replaced.
There are sets of wheels out there for the cost of one OEM replacement.
thoughts on running 18x8.5et 35 235/40/18 & 18x9.5et35 265/35/18?
I'm open to running spacers, would prefer not to. Thanks for the help!
Old Apr 7, 2020 | 10:16 AM
  #572
Howyalivin's Avatar
Acura TL-SH, among others
Is there a way to get a little more concavity on the front wheels?
Old Apr 8, 2020 | 07:16 AM
  #573
TModelle's Avatar
C190
Sadly, no. There’s just so little concavity to be had on this platform.
Old Apr 9, 2020 | 03:38 PM
  #574
Hungalow's Avatar
C43 2017
went with cheaper rims as I will be returning car after lease...I will just sell them before return and the amg 18" oem will serve as my winters. They are 20" ...rears are 10" wide...fronts are 8.5" with 5 mm spacer. I was gonna go black but happy with the chrome..more pop...CHEERS
Old Apr 18, 2020 | 12:19 PM
  #575
Rh6363's Avatar
Mb c43 2019
i am interested in this as well. Anyone have any input.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
