Need car stereo help (wire harness).
Is there a wire harness and/or kit for a DD aftermarket stereo install for the 1998 CLK 320? (mine has the tape deck with the "phone" underneath it and a 6-disc changer in the trunk)
I'm not sure if it's Bose, but it has components and an amp in the LR of the trunk.
I've searched everywhere and I can't even find any information about it, let alone find a harness. I can get the pin-outs and hard wire it myself if I have to, but I'd rather have a clean install.
I saw someone post that there is a harness that fits perfect, but it's listed as being for a different model.
This is the first time I've ever seem something like this (Metra, Crutchfield, ebay......nothing!)
All help is appreciated.
Thanks,
If you follow that video and do the DD install succesfully, it would be great if you can post a write up and some pics!
I got three minutes into that video and had to stop.
I wouldn't let that guy touch my car. The RCAs he's talking about are supposed to plug into your new (aftermarket) stereo and the opposite end has a harness, which converts the RCAs into regular wires, which then feed the input signal into your stock amplifier (the way RCAs would).
I don't need someone to show me how to wire a stereo. I've been doing stereos for over 20 years. I'm trying to figure out why I can't seem to find a wire harness for this car. I've never seen anything like it. There has to be some reason why I can't find a harness. I don't see any reason why it would be impractical to make one.
Worst case: I'll take an Audi harness and modify it. If it comes to that, I'll do a DIY video, but I haven't bought my new deck yet, so it won't be right away.
Thanks for chiming in though! All help is appreciated.
That is exactly what I was looking for. Thank you very much!
I plan do do what MarcusF suggested. I haven't read the article yet, but I can already tell that it'll work fine. I'll do a write up or a DIY video on it once I do mine. Hopefully that'll help you out a bit.
The Yellow (constant) and the red (acc) need to be switched and the remote wire needs to be plugged into the new harness. After that, you should be fine. Here's a thread I made after I finished mine. Unfortunately I completely forgot to do a write-up. It's pretty straight forward though.
MarcusF was right on the money. Thanks again for that!
Here's what I did: https://mbworld.org/forums/clk-class...tooth-one.html
I hope that helps a bit.
G/L
G/L
Here are the ignition switch positions corresponding to when the12 volt supply is present.
15 = switched battery power, hot in positions 2 & 3
15R = switched battery power, hot in positions 1, 2 & 3
30 = unswitched battery power.
87 = powered via (unspecified) relay.
Constant and switched power come from the harness to the radio. Remote power comes from the radio to the harness.
G/L.
Take a look at what my stock harness looks like.
You can see the plug "C" has
Pin 4 = Battery Voltage (Constant)
Pin 8 = Ground
Pin 5 = Amp Connection
but there is no pin 7 which would be for switched power.
I have tested all wires with my multimeter and none of them are switched on any of the Plugs. Convicted, I suspect this is a difference between my 2002 and your 1998
