E-Class (W214) 2024 -
2024 E 350 panoramic roof exploded. Mercedes Benz Canada will not provide warning
Old May 26, 2025 | 04:19 PM
NFB's Avatar
NFB
2024 E350
Our car was four months old and the rear portion of the panoramic sunroof exploded.
A third party looked at the roof and said it wasn’t a rock, so did insurance. Mercedes Benz Canada will not warranty their product.
Old May 26, 2025 | 04:43 PM
W205C43PFL's Avatar
Oh no : ( not on the W214 already, it happens, it is an issue across multiple brands, different brands react differently though. I wonder what recourse you have, hopefully something good. Good luck OP.
Old May 26, 2025 | 04:44 PM
W205C43PFL's Avatar
You confirmed it wasn't caused by external stress like a rock on the highway that slowly expanded and exploded?
Old May 26, 2025 | 04:46 PM
W205C43PFL's Avatar
Welp, I don't know why I just asked that question because you clearly say they confirmed it wasn't a rock, if they can confirm it isn't a physical impact they have no basis to deny warranty, no?
Old May 26, 2025 | 05:17 PM
NFB's Avatar
NFB
2024 E350
The dealer didn’t even take the time to look at it. I called Mercedes Benz Downtown Calgary and over the phone they said it was a “rock”.
It wasn’t a rock.
The only concern they had was my 1 star google review!! I was generous.
They did suggest an auto body that I could go to as they don’t have the ability to repair it themselves and they would appreciate the parts order!!!
The roof panel may take 3 to 4 months as it is in back order.
Old May 26, 2025 | 06:31 PM
W205C43PFL's Avatar
It wasn’t a rock.
If it isn't a rock and actual internal stress and got proof for it, they have to cover it under warranty.
Old May 26, 2025 | 06:56 PM
W205C43PFL's Avatar
Did you try a different mb dealership?
Old May 26, 2025 | 07:31 PM
NFB's Avatar
NFB
2024 E350
Mercedes Benz Canada made the decision.
They opted out of the government of canada arbitration process just a week before our roof exploded. It would appear that the process didn’t treat them well. Other manufacturers are still part of the process.
The pictures taken by the third party were submitted to the dealer and Mercedes Benz Canada after they said they still wouldn’t cover the damage under warranty.
Insurance will cover but this is a cost all consumers bear as it should be a responsibility of the manufacturer of all brands.
Laminated glass would go a long way in preventing this problem.
The insurance company said this is becoming quite common.
Old May 26, 2025 | 07:34 PM
NFB's Avatar
NFB
2024 E350
Mercedes Benz Canada opting out
Old May 27, 2025 | 02:34 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W214 forum...
Old May 27, 2025 | 02:45 AM
L1Wolf's Avatar
Veteran: Army
W214 E450
This is indeed troubling. How was it determined that a rock or other hard object did not hit the glass? Im not saying it was a rock or something similar, but curious how it was definitively ruled out.
Also, what was the car doing when the glass roof exploded? Was it parked? If so, where? Were you driving? Did all the glass land in the car or did some/most go outside of the car?
Old May 27, 2025 | 02:58 AM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
W203 Sport coup has a recall for this....like 15 years too late.
Webasto makes these roofs.
Old May 27, 2025 | 08:34 AM
NFB's Avatar
NFB
2024 E350
Auto glass company inspected it. They had seven that month and their store alone. Mostly Hyundai. Pictures were taken no foreign debris and outward explosion.
We were on the highway exiting at roughly 80 kilometres. The roof exploding sounded like a gun went off. There was a 30 degree centigrade temperature as the weather got warmer over a four hour period. The liner was fortunately closed so the glass did not shower into the interior.
I had inspected the car in morning as it had never spent anytime outside of an underground parkade. I’m very particular and the car is thoroughly cleaned once a week.
Old May 27, 2025 | 09:45 AM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
I have inspected many 2024 and 2025 e-class models as I don't like the fitment of the rear portion of the panoramic roof. All models exhibit the same characteristics- the rear portion is raised ever so slightly at the back of that panel. And if you follow the rubber seal at the parallel edge to the car - it meets the glass at the front, but quickly falls away as you move back due to the rear portion of that section being raised. Not sure if this correlates to the failure.
Old May 27, 2025 | 11:14 AM
L1Wolf's Avatar
Veteran: Army
W214 E450
Its good the sun blind was closed and you didn't get glass all over you and your passengers. Im surprised its not safety glass. Does your car have the sound insulation glass?
Regarding cause, I don't see how the absence of foreign debris is anything conclusive. A rock traveling at 100kph from being kicked up by another vehicle hitting your car/roof traveling at 80kph could easily land far enough away to never be seen again. Plus, with it being outside, I'm sure there were plenty of them all over the place where you stopped to inspect. I suspect the lack of a rock or foreign debris in the car is what was meant, but its quite conceivable that a rock could have hit it and bounced away outside the car. If the car was motionless in a garage then I would say its highly doubtful, but driving at 80kph its much more plausible that something hit it rather than it just spontaneously exploding. I know it happens to glass though. I had a glass shower door shatter when I was sleeping. Nobody was near it as it was 3am. Glass was everywhere.
The anecdote that seven other cases with most being Hyundai is not really relevant since they could have all been due to external factors and its different cars with different glass. There are hundreds of thousands of cars with all glass roofs that don't explode for no reason. I'm sure some do and have. Maybe yours did, but its just as likely (perhaps even more likely) that something hit it.
Old May 27, 2025 | 12:13 PM
NFB's Avatar
NFB
2024 E350
We kept the thumb drive of the outside camera and there was no traffic present. It’s a pretty rural area.
Mercedes Benz USA is involved in a class action suit in regard to exploding sunroofs, evidently this is not an isolated incident.
The insurance company also agreed that is was not a foreign object but did agree to repair the car. BMW, Hyundai and Mercedes are prime culprits.
I was told by the insurer that court action is very difficult as the manufacturer will make this a very long and expensive process.
Again the consumer comes out on the short end of the stick. Higher premiums for consumers that have panoramic roofs and a manufacturer that passes the liability to the consumer.
Old May 27, 2025 | 12:18 PM
NFB's Avatar
NFB
2024 E350
This problem has become prevalent enough that a physics professor from Berkeley has weighed in. “A rock has to be traveling at 80 mph from a height of 25 feet to break a sunroof”
Old May 27, 2025 | 02:35 PM
L1Wolf's Avatar
Veteran: Army
W214 E450
With no traffic nearby, it certainly is less likely a rock, but not impossible. Interesting that there is a class action on this. I looked it up and found some details here. Another article here, says that a judge in GA trimmed the case and threw two plaintiffs off the suit because they "shown their damaged vehicles to their own car dealers, rather than notifying Mercedes about the defect before filing a complaint, as required by warranty". Another article here says a class action case was dismissed and another, here, for the same case mentions that the manufacturer warranty specifically does not include "glass". I've been driving an E with a pano sunroof since 2014 and have never heard of this before. I totaled my 2012 E350 hitting a tractor-trailer that broke both right door windows and the rear window, but the all glass roof remained undamaged. Even with the A, B, and C pillars being completely bent in. Im not doubting that many roofs just exploded for no reason, but clearly it's not happening to all of them. I wonder if some glass panels had defects during manufacturing that cause this. Ideally it should be laminated glass on the roof. I believe the sound insulated glass is laminated.
It depends on the size and structure of the rock or object. In addition, 80mph is easily exceeded when you consider a car moving forward at 60mph and a rock traveling in the opposite direction at 60mph. Now the speed is 120mph and could easily be much more. Not saying the physics professor is wrong, but there are many factors involved here. Windshield glass breaks all the time from rocks, but the angle is more direct than roof glass.
In any case, I hope you get this resolved. Had to be pretty scary when it happened. MB should make this right. At least insurance is covering it.
Old May 27, 2025 | 03:55 PM
NFB's Avatar
NFB
2024 E350
I agree, thanks for your insight and concern.
Old May 27, 2025 | 05:16 PM
W205C43PFL's Avatar
Outside camera? We are not talking about the built-in dashcam right?
Old May 27, 2025 | 05:17 PM
W205C43PFL's Avatar
CAMVAP was always useless nothing at all close to US' lemon law.
Old May 27, 2025 | 05:20 PM
W205C43PFL's Avatar
Welp at least MB was once opted in to CAMVAP before, bmw never was in CAMVAP in the first place.
Old May 27, 2025 | 05:22 PM
W205C43PFL's Avatar
I don't think OP tinted their sunroof glass but I seen reports of tinted glass causing explosion issues on the forums before. I have yet been able to locate such thread.
Old May 27, 2025 | 05:31 PM
W205C43PFL's Avatar
I end up finding several threads (on different models) talking about the tinted sunroof causing explosion but like I mentioned, OP unlikely tinted it:
https://mbworld.org/forums/e-class-w...amic-tint.html
https://mbworld.org/forums/glc-class...shattered.html
https://mbworld.org/forums/glc-class...00-4matic.html
https://mbworld.org/forums/c-class-w...shattered.html
https://mbworld.org/forums/c-class-w...-louis-mo.html
Old May 27, 2025 | 06:19 PM
TulsaVic's Avatar
2025 S580
This was written about on the Volvo SwedeSpeed forum. There they referenced a Consumer Reports article: https://www.consumerreports.org/car-...nger-overhead/
