Yeah - same. I see on the BATT-LIN topic that disconnecting this can disable the start/stop -- is that true?
...And, while that does look like the right schematic for my car, I would never cut into anything without being 100% sure of what it is .
I've decided to go back to basics and just monitor the voltage for now. If it doesn't cycle, I suppose I can infer from this thread that I am not having issues? I suppose this doesn't mean the CAN isn't having errors/retransmissions, but it seems like voltage fluctuations is the signal that something should be addressed.
1 - ALT-LIN does disable the amazin' ECO Start/Stop. No programming necessary.
2- By design Voltage swings at least from float to bulk.
That is what's being solved here.
If you don't have engine lag, tranny issues or extreme heat then no reason at all to sway from stock.
I don't think I have any issues on this platform. It will put down 3.3s 0-60s all day long (although I am usually very selective of when I bring the hammer down) - but free mods are always intriguing .
Laggy throttle is only at the bottom RPM, not under WOT. although during acceleration ppl have recognized weak fuel delivery.
This benefit throttle control for regular driving. Normal fuel map is busted lean by poor ignition to cause lag.
Makes sense. I have noticed that it can lag a little when leaving the line in casual driving, but it's slight... I have a note in my mind to check the throttle body if I ever take the intercooler off. Maybe the voltage issue is what's really going on. Maybe the monitor will tell?
Yes, now you know! It's not oily throttle body.
Actually the whole fuel map under 3000.Rpm is abnormally leaned out by poor combustions.
How do we know.... because we fixed the root causes.
Do you know battery voltage under WOT ??
Is it the same as stock accelerations when ECU drops voltage?
Try these simple steps here!
ECU self-tuning is very gradual by nature...
Results depend on how lean you begin with.
Speaking of BATT-LIN, you could also just unplug the battery sensor but it probably doesn't do the same thing, at least not exactly as the ECU still can communicate to the ALT. https://mbworld.org/forums/mercedes-...ml#post9097659
Which engines are yielding the most benefit from this mod? I haven't noticed any lagging throttle witm my M176 V8 TT.
So far M276 engines benefits the most from this mod, not saying the M176 doesn't just that not a lot of people have tried it yet and report back so there is not enough data for the V8s. That said, pretty much all recent MB engines (pretty much any MB engine with the 2 stage valve control solenoid)benefit from the oil pump solenoid mod though.
No lag/less lag is very good news for owners
-- You can get an easy sort of preview without any modifications...
-- Try or keep using the "HL:ON" trick to get stable voltage for best ignition and associated fuel maps improvements.
-- In addition floating your main battery is always a positive step
-- Then monitor IC display to report what Voltage/Amperage :
any voltage variation ?
any throttle improvement?
-- Get the engine used to running "HL:ON" fixed voltage CONSISTENTLY TO ADAPT better voltage.
Notice response improvements?
> M176 EXTREME HEAT... Tstat:
-- This engine is recognized to have extreme heat causing Tstat issues... what makes this worse are POOR TIMINGS causing LEAN Mixtures.
-- Meaning Tstat is the "tip of the iceberg": it does not cause high heat but gets coooked by high heat. @streborx
-- experiment with better RPM pistons spray cooling pressure (SOLENOID + VISCOSITY)
-- experiment with STABLE VOLTAGE to improve timings.
Hello everyone, I am a new member of the forum and I have a w212 220 cdi 2012 om651. I have a strange problem, my car always starts fine when it is cold, but there are times when it delays starting a little when the temperature is above 30 to 85 degrees. I have changed the crankshaft sensor and I have changed the oxygen sensor. Yesterday I took it out of service and today strangely after more than 15 starts it did it again. I reiterate that only when it is warm does it cause the problem. thanks
Just for Cali, I made a modification today. I added a chassis to engine ground strap.
On the strut tower, there are three little holes that I have no idea what they are for. So, I took a 6mmx1.0 tap and threaded one of the holes. I had a 6mm bolt that I used to attached one end of the cable to strut tower and the other end to the timing case near the oil filter. This was a quick job and I may need to change the connections, but I thought for now I would do it and see what happens.
and for Mstr Surya too...
We enjoy reliable GND circuits - Tons of weird electronic problems never to be had
Underated capacitors won't get overheated by significant ripples.
> Fun testing:
During installation... before closing the circuit see if you can light up a sensitive test-light between chassis and engine GND or use a DVM.
