---> CALI's hands-on ... STABLE CHASSIS VOLTAGE !!!
Old Jan 15, 2025 | 09:29 PM
  #51
W205C43PFL's Avatar
https://cimg5.ibsrv.net/gimg/www.mbworld.org-vbulletin/1080x860/screenshot_20250115_180315_amazon_shopping_73f8357 70d266cd93f1d922f7fcafb80a4b7567e.jpg
easy way to keep an eye on chassis 12V-DC
This does USB Charger plus monitor
Very useful to monitor voltage without BATT-LIN disconnected.
Voltages witnessed at different branches of prefuse box are slightly lower due to drop-voltage.
My dashcam also shows voltage live : )
Old Jan 15, 2025 | 09:40 PM
  #52
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Thanks for bringing this mod to the attention of us forum members, these quality of life improvements are nice to have : )
you deserve a reliable Benz to drive in Canadian polar weather.
​​​​​The honest way to deal with chaos is to cancel it.
Old Jan 15, 2025 | 10:51 PM
  #53
W205C43PFL's Avatar
Thanks again, I will need to try to get it done from the top if it is ever possible otherwise I might need to postpone it till later, my back has been hurting lately. Thankfully many others that come across your thread can enjoy the mod in the meantime, thanks again : )
Old Jan 15, 2025 | 11:45 PM
  #54
JettaRed's Avatar
Veteran: Army
I had a bad back. The orthopedic surgeon wanted to operate, showed me my MRI and said I'd been in a wheelchair soon. That was over three years ago. (If you're a hammer, everything looks like a nail. If you're a surgeon, you cut.)
A veterinary pharmacist I was doing some work for said to start taking Turmeric, NAC, and Quercetin. Turmeric is an anti-inflammatory. Quercetin and N-Acetyl Cysteine (NAC) are immune system and antioxidant support. It's all OTC stuff. Within two weeks, the pain was gone and has stayed gone.
Old Jan 16, 2025 | 01:41 AM
  #55
THERE YOU GO !
That's great advice, thank you JR.
In your list of special pills you can add Bromelain: a powerful anti-inflammatory compound extracted from pineapples.
> TWO HOURS HIGHWAY ROUND TRIP:
Surprise the mpg just climbed to efficiency unseen in over 10Yrs.
32.7mpg on flat highway (no hills) !!!
32.7mpg driven on flat highway (no hill or grades) !!!
Here's what I got just now: 32.7mpg driving highway speed. This is better than before ALT-LIN
I am going to conclude :
-- Regenerative deceleration burst is a waste mpg.
-- Stable voltage is significantly more efficient
> GREAT DRIVEABILITY :
-- I enjoy my ponny efficiency with more power and less heat.
-- It's a different driving experience with the seemless gearbox.
-- The electric steering bias is noticeably stable and the California hills are flat!
-- There's no need to muscle heavy chassis into higher rpm then squash the brakes to slow down.
-- It's a more nimble Mercedes with less overall wear and tear.
-- This is a matching extension of MOD-4 with further throttle granularity.
-- Even the tranny needs to adapt a bit to the engine voltage upgrade (tinny bit of weirdnesses at first replaced by great behaviors to match engine)
Old Jan 16, 2025 | 08:11 AM
  #56
JettaRed's Avatar
Veteran: Army
Old Jan 16, 2025 | 09:52 AM
  #57
W205C43PFL's Avatar
https://cimg6.ibsrv.net/gimg/www.mbw...76d5b59337.jpg
https://cimg8.ibsrv.net/gimg/www.mbworld.org-vbulletin/274x427/image_613d6679ffa7556d3a7c0b5ba2387fbe74a44f81.png
Wow, thanks so much both of you words really really can't express how grateful I am, these are probably life saviours, I will look into these right away.
Old Jan 16, 2025 | 09:57 AM
  #58
W205C43PFL's Avatar
Forum member, CaliBenzDriver, in regards to the connector, do you have an image of the connector or the name/style of connector on both front and back side that can be found online, that will hopefully help too : ) For example is it a Hirschmann or Sealstar, if so which one? Key A or Key B? Thank you : )
Old Jan 16, 2025 | 12:54 PM
  #59
fixing both CARS + DRIVERS 👏
Brom + Querc
Brilliant, thank you JR!
I am going to upgrade my standard Bromelain to combination level.
Vit.D2 from AMZ
Vit.D2 from AMZ
I you understand Vit.D3 to support healthy immune functions, then look into upgrading to Vit.D2. It helps protect the lungs cells.
uncommon holistic troubleshootings.
Old Jan 16, 2025 | 01:05 PM
  #60
EASY DOES IT.... BLINDLY
This is way more simple than researching connector type. The hard part is releasing the tinny lock in one piece
-- You need to work by feel blindly sight unseen
-- ALT only has one single connector (besides the heavy gauge 12V out)
-- It uses a dual-lock like CPS connectors
-- Pull back the fragile lock from the top edge by hand
-- Gently rock the lock to release connector while you pull out tocking side to side.
There you have the blind extraction of ALT-LIN.
Old Jan 16, 2025 | 01:08 PM
  #61
JettaRed's Avatar
Veteran: Army
Just say you throw a couple D2 pills in the gas tank every couple of fill-ups so no one accuses us of going off-topic!
Old Jan 16, 2025 | 02:05 PM
  #62
W205C43PFL's Avatar
I need more assistance : (, I am confused, what is this thing? I don't see nor feel any connectors pictured in the thread, viewing from the top with phone flashlight: (
Old Jan 16, 2025 | 02:20 PM
  #63
BLINDLY PULLING BY FEEL
yes you got it, I think this is your ALT-LIN connection
Some alternators models have it Located Near The Edge at the rear like yours.
Feel your way around that skinny wire...
Feel the lock lever
Pull it out
.... procedure above
>> Not to be confused with the tall plastic cap over the ALT/BATT output: ALWAYS 12VDC LIVE POWER (Dont short this! - Don't mess with it - That part is built to be reliable)
You will need to confirm the alternator output voltage is self regulated as ecpected and EVU is flagging the disconnect as well.
Old Jan 16, 2025 | 02:24 PM
  #64
W205C43PFL's Avatar
I think this is your ALT-LIN.
Some alternators have it located near the edge like yours.
Feel the lock lever
Pull it out
Not to be confused with the tall plastic cap over the +12V output ALWAYS LIVE POWER.
I thought that was my ALT-LIN too as that is the only wire coming off from the alternator other than the round 12v one but the wire is not blue and it is nothing like the connectors ever shown in the thread, I wonder if MB changed it to a permanent connector since the W205 C-Class, if so that will be unfortunate.
Old Jan 16, 2025 | 02:25 PM
  #65
W205C43PFL's Avatar
@Manny_c450 Is that how your connector looks like as well?
Old Jan 16, 2025 | 02:28 PM
  #66
look up your ALT spare part on the Internet .... it will show you matching connector style.
Old Jan 16, 2025 | 02:34 PM
  #67
W205C43PFL's Avatar
For my car the alternator used seems to be 0009068706, the connector looks right like yours and forum member JettaRed except when I look at my car, and felt around that wire and connector there is no clip at all
https://www.autohausaz.com/images/VL...pg?size=medium
Old Jan 16, 2025 | 02:38 PM
  #68
it maybe exact same connector but located on the edge like yours or in the middle like ours.
perfect match ... on the rear edge
meaning same connector has the same latch to pull up
Old Jan 16, 2025 | 02:39 PM
  #69
W205C43PFL's Avatar
and... the connector looks completely different.
Old Jan 16, 2025 | 02:40 PM
  #70
W205C43PFL's Avatar
Mhmm from the part number and the way it is on the side facing passenger wheel well away from engine is the exact same as forum member JettaRed except the actual connector feels nothing like it which is why I was confused.
Old Jan 16, 2025 | 02:42 PM
  #71
similar latch...
do you see the latch tong?
same
similar
Now you can see where the latch is facing
I don't think it is different... the connector you pull out covers the whole alternator male/female piece
Old Jan 16, 2025 | 02:43 PM
  #72
W205C43PFL's Avatar
https://cimg2.ibsrv.net/gimg/www.mbw...93efbaf4b7.jpg
similar
I don't think its different...
Me neither it is strange, I don't think it should be different either.
It is not there...
Old Jan 16, 2025 | 02:52 PM
  #73
almost there...
It is not there...
my connector would fit your alternator!!
  • Now that you know where latch is facing
  • reach in and feel your way to identify latch
  • pull it
  • then off it goes
done! big hand
Old Jan 16, 2025 | 02:54 PM
  #74
W205C43PFL's Avatar
You know where latch is facing, right
pull it and off it goes
done! big hand
Mhmm, the latch would be further to the back of the alternator so in the image shown I uploaded it will be further back towards the bottom, except there is no latch, unless someone broke it before but doesn't make sense, I bought this 2017 since new. I will try again, appreciate the pointers, thank you again
Old Jan 16, 2025 | 03:07 PM
  #75
FREEING YOUR ALT-LIN CONNECTR....
if you need more confidence look at pics of the connector you're trying to remove.
In particular the tinny plastic lock at the top... be gentle it's undersized German plastics
if you want to save time, just look at CPS connectors: same tiny lock style.
-- It uses a "dual-latch" just like CPS connectors
