---> CALI's hands-on ... STABLE CHASSIS VOLTAGE !!!
https://a.co/d/cZOtdCI
Big pipe is low pressure cold-return to compressor
Skinny pipe is high pressure hot-side to expended coil.
Feeding is done only on low-side, the compressor suction side.
I think this is had to do with Compressor valve issue (not TXV).
spit-test for bubbles!?!
Don't rush to the parts canon.
You do have considerable pressure.
While your compressor valve is pegged at 100%, what does the pressure do:
OBDII Hi side sensor goes up??
(Lo/Hi side gaugeset)
> Low charge vs. bad prop. valve:
-- Low charge should pump up high side
-- Stuck prop valve will keep compressor pressure unchanged
-- High side going from 6B (87Psi) to 7B (100Psi)
My money is on the "PWM valve", not a leak.
Of course pressure depends greatly on heat, 100psi is not a lot of pressure for cooling.
The key for cooling is the differential between Hi/Lo side. (If both sides are at 180Psi there still be zero cooling).
Right now I am guessing your low side is not being pumped down. Use gauge-set to see differential pressures.
These may be simpler:
They are not here to help, only token for the real problem that's infact usually somewhere else.
To make decisive progress, you've got to analyze available evidence/clues while answering:
is it A or B else C.
Here you have medium pressure thats not pumped up... prop. valve!
Before rushing at opening sealed circuit, you check differential pressures to confirm compressor is not pumping besides commanded at 100% duty.
The wobling plate is staying idle.
without replacing while unit Toyota uses the same compressor with spare parts available.
This shows how to listen for rattling with scope sensors.
Attached the pressure temp chart
Make sure engine is at ambient temperature ( 12 hours shut down minimum ) and use the Launch to see the pressure.
Compare it to the attached chart. based on the temperature reading of the engine metal or ambient.
Pressure alone can not verify R134A fill is proper or not proper, even at 50% gone, you will still get the pressure as per temperature.
The typical natural loss via the compressor seal is 8 grams per year. Your car R134A fill woud be close to mine at 590grams....but must check WIS.
Only RRR machine or equivallent can confirm your refrigerant fill level in grams. You can not use pressure to define proper R134A fill...NO WAY.
Scenario 1 :
If yours is clutchless AC compressor , that means no B09* option .... it is most likely that AC valve is the issue.
*B09 option means AC comp has clutch.
Albeit you are seeing power sent to the AC solenoid, that up to 950milliamps of current, that does not guarantee the AC valve actually open up.
Scenario 2 : Which is most unlikely....I pray it is not the case
Your AC compressor is shot, it can't produce pressure at all as in total loss of compression...again , it won't be this bad suddenly, it will be progressive.
As to why you seeing pressure rise to 7.x BAR, is because when engine is ON, it heats up the HVAC component and pipe and thus raise R134A pressure by virtue of slowly rising hotter temperature.
Scenario 1 :
Ppl say A/C oil needs to be circulated. There's no trace of corrosive water inside. Seals get hard due to extreme heat.
You know what's a small world with oil topic ??
compressor oil is used to seal 200.Psi compression of 5x pistons.... much like 5w-50 oil for engine wet ring seal.
Less pressure losses means more efficiency !!
I think it is the seals in the PWM solenoid valve that are guaranteed to hold back the plunger. That holds the compress plate near neutral, unable to pump up gas into liquid.
