Oil pump solenoids
Old Jun 23, 2024 | 07:49 AM
  #1926
gumsie's Avatar
AMG CLS63S SB.
1. Buy a oil pump solenoid and connect it externally to the harness then ziptie it to somewhere safe, then you won't have the code. Or alternatively have the code coded out but this is not easy and I am not sure how. https://mbworld.org/forums/w212-amg/...ml#post8939117
2. It is definitely quieter and smoother, I wouldn't say faster but the gas pedal is more reactive.
Ok, fair enough. Never thought of that.
Haven't gotten around to it yet as it looks like such a PITA to do without a vehicle lift.
Old Jun 23, 2024 | 07:50 AM
  #1927
W205C43PFL's Avatar
My impressions after the unplug and no it isn't in my head, I have passengers said I was driving more aggressively when I said I drove the same way as I always did. https://mbworld.org/forums/w212-amg/...ml#post8963720
Old Jun 23, 2024 | 07:51 AM
  #1928
W205C43PFL's Avatar
Originally Posted by juanmor40
The current wisdom is that once disconnected for a while , you never connect it back to prevent a possible catastrophic engine damage since we have no clue if something is accumulating in that area
Ya, true since there is no circulation there anymore.
Old Jun 23, 2024 | 07:52 AM
  #1929
gumsie's Avatar
AMG CLS63S SB.
No worries, now just need to get under it, and over it, to the side of it etc etc.
  #1930
W205C43PFL's Avatar
Sorry may I kindly ask what car do you have, your signature might be outdated 1996 CL 500 doesn't have this annoying solenoid.
Old Jun 23, 2024 | 08:02 AM
  #1931
W205C43PFL's Avatar
You can buy an OEM solenoid or buy this for half the cost but wait a while for it to arrive: https://mbworld.org/forums/w212-amg/...ml#post8981405
Depends on how quickly you want to do this mod or how valuable your time is : )
By the way, get a set of these as well on that same site since you are waiting anyways, you want to have them to cap off the live harness and the inactive connector port on the oil pan sid to seal it from dust/dirt/moisture. Especially on the live harness, you don't want a short circuit or any type of damage from the elements for that matter: https://mbworld.org/forums/w212-amg/...ml#post8981915
Here is forum member S-Prihadi's post on this harness: https://mbworld.org/forums/w212-amg/...ml#post8981421
Old Jun 23, 2024 | 09:11 AM
  #1932
gumsie's Avatar
AMG CLS63S SB.
Agh, sorry. I'll get that updated in two ticks.
CLS63 though.
Old Jun 23, 2024 | 09:15 AM
  #1933
gumsie's Avatar
AMG CLS63S SB.
I wanna get it done soonish I think but I'll order what I need up front first and make sure all is properly planned ahead.
Old Jun 23, 2024 | 09:25 AM
  #1934
W205C43PFL's Avatar
CLS63 though.
Ah gotcha, so the M157 engine, great engine but tight space ya sadly you do have to get it done from the bottom, I was hoping there was a way you can get it done from the top, which forum members were successful on certain engines.
Good luck on the unplug and hope you enjoy the benefits.
Old Jun 23, 2024 | 09:28 AM
  #1935
gumsie's Avatar
AMG CLS63S SB.
I was really hoping you weren't going to say that. I'll pop the bonnet and order the parts before I attempt but thank you.
Old Jun 23, 2024 | 09:32 AM
  #1936
W205C43PFL's Avatar
Sorry for being the bearer of bad news : (
Edit: I do wonder if you can get away from lifts/hoist with by just using jack and jack stands and/or ramps?
Old Jun 23, 2024 | 09:43 AM
  #1937
JettaRed's Avatar
Veteran: Army
Does anybody know where the cable from the oil pressure solenoid actually routs to/through?
I'm pretty sure you mean the oil pump solenoid.
I have been able to disconnect the solenoid on both my cars from the top. You do need to remove the intake hose that runs from the front of the car to the air filter(s) to get unobstructed access. However, if you have Popeye-sized forearms, you will have difficulties. Maybe post a pic of the front of your engine to give us an idea of the workspace you have. On my C-Class, there is less room to work. On my SL, the intercooler obstructs the view, so it's more by feel.
Old Jun 23, 2024 | 09:44 AM
  #1938
kevm14's Avatar
04 E55 AMG (totaled), 07 S550 4Matic, 14 E63S
I would think a CLS is packaged like an E so....looking at bottom only.
Old Jun 23, 2024 | 09:45 AM
  #1939
W205C43PFL's Avatar
Ya but they have a M157 with the V8, not our M276 : (
  #1940
JettaRed's Avatar
Veteran: Army
...I do wonder if you can get away from lifts/hoist with by just using jack and jack stands and/or ramps?
Yes, ramps or jack stands are sufficient if you raise the car high enough to get under it to remove the splash trays.
Old Jun 23, 2024 | 09:47 AM
  #1941
JettaRed's Avatar
Veteran: Army
I keep forgetting...
Old Jun 23, 2024 | 09:50 AM
  #1942
W205C43PFL's Avatar
All great engines, just some have less (breathing) room if you will : )
Old Jun 23, 2024 | 11:11 AM
  #1943
gumsie's Avatar
AMG CLS63S SB.
You are correct yes, I do mean pump and not pressure.
Probably early one morning I'll have a go at it. I'll put up a pic from above in the not too distant.
Old Jun 23, 2024 | 11:15 AM
  #1944
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
no in/out !!
I'm thinking that I can find somewhere else and put in a switch or plug and socket to enable me to connect and disconnect as I see fit.
Thanks.
This is really NOT "plug N play" feature! I recommend against going back and forth between MOD-0/1 at your own risks.
The ECU mapped cam positions is not friendly to oil pressure variations besides your solenoid can jam and toast your engine on low pressure without even knowing it... RIP!
> Unplugging MOD-0 solenoid has limited cooling benefits (MOD-1) until you provide an oil that can take advantage of viscosity to build pressure when pumped volumes are limited: MOD-2.x
Engine power and response transformation is handed out by ECU with solid precise timings conditions. That's the opposite of back and forth testing with burnt thin oil.
Happy experimental testing from your MOD friends.
Old Jun 23, 2024 | 11:17 AM
  #1945
gumsie's Avatar
AMG CLS63S SB.
I have both chocks, stands and a trolley jack. But I I will surely check I have everything first. Just tryignto think if I need anything from FCP Euro before I place the order.
Old Jun 23, 2024 | 11:18 AM
  #1946
gumsie's Avatar
AMG CLS63S SB.
Engine power and response transformation is handed out by ECU with solid precise timings conditions. That's the opposite of back and forth testing.
Ok, noted. Thankyou.
Old Jun 23, 2024 | 11:47 AM
  #1947
W205C43PFL's Avatar
Ya sadly most of MB engines don't have an oil pressure sensor, not even a real oil temperature and coolant temperature sensor oof.
Old Jun 23, 2024 | 11:48 AM
  #1948
W205C43PFL's Avatar
Sounds good, good luck!
Old Jun 23, 2024 | 01:05 PM
  #1949
gumsie's Avatar
AMG CLS63S SB.
[b
> EASY CHOICES: [/b]
"MB Approved" choices to remove core heat are very few good candidates:
  1. Mobil1
  2. LiquiMolly
  3. Motul
  4. Pennzoil
  5. ​​​​​Amsoil
You can SIMPLY RANK OIL BY VISCOSITY and select what you need within your comfort zone.
I'm surprised that Petronas isn't listed here given they were an MB F1 sponsor.
Old Jun 23, 2024 | 01:23 PM
  #1950
- The whole list is the MB229.5 specsheet besides it not supporting 10/15W-40 viscosities.
- Every oil companies market great products.... some more useful than others for our purpose.
- We respect personal choices even stock viscosity with limited cooling. Your results with be directly tied to effective viscosity not the brand.
You have already rated this thread Rating: Thread Rating: 14 votes, 4.29 average.
