THE blower thread
Thanks soooo much for the help guru of FASSSST CLK's.
PS - keep me in mind if you sell your autorotor
Haha no worries, always happy to help.
Will do, alot of people have said the same thing about the autorotor loll
You'll laugh at my current real-time fuelpress/boost setup...... I took some mechanical Autometer gages with cup style gage pods and mounted the gages to a pad which I temporarily tape to the windshield for a few pulls to see what the car was doing. The redneck side of me actually kind of liked the gage pods near the cowl.... but sooooo no MB style
You will find having the ability to read boost/vac, fuel press, afr while driving a big plus..... with all of these mech/electronic gadgets tricking the stock ECU for critical functions like fuel, timing.... you want to monitor things occasionaly in case something go amiss. The consequences are $$$$$
Okay, so I need to order the bundle plus 2 pressure sensors, one for boost/vac and one for fuel. I'm also going to order the dual wideband package so I can monitor both banks.
BB - SLR injectors.... I'll order some.
Auto-rotor needs to come to houston to reside on my car
Slowly copying BB and PTE for a mutt of a fast car hopefully.
Kev - if you only run 1 O2 sensor put it on the drivers side bank as I understand it is the most likely prone to go lean 1st!
So I could put this blower on my clk55 with lower c/r pistons and pulley down for some real power. (hopefully more to come)
https://mbworld.org/forums/w211-amg/...-progress.html
It can be yours at a price haha
Update on my car tonight...... really wanting to hit the track Fri PM in good air.... I pulled my klee rheostat and check actual ohms disconnected from mas circuit. It read 650 ohms, and my mass is reading max volt of 5.11 @ WOT under full load.
So I tried making a check @ 750 ohms.... volt down to 5.02,
Then 900 ohms.... down to 4.97,
Then 1000ohms.... voltage down to 4.96-4.97 (below 5 finally).
To get to the rec 4.85 max (rec by Klee), I'll have to crank this rheostat way over 1000ohms. Assuming it's a linear relationship... then 1350 ohms should get me down to 4.85max....... BUT the klee rheostat box maxes out @ 1000ohms. So the best I can do is 4.96-4.97volts.
I guess I'll bug cory again... to see if I'm allowed to add in another resistor on top of the klee box to get to 1350 ohms??????
IF I install this larger MASS AIR METER, I'll def need a tune.
You can see the 3.5" OD tube fits the stock lower TB Elbow, I'll need to get my hands on a stock y-pipe to test fit, but this should work fine.
I've got a mapp gas- al weld rod kit which I might try to braze the flange on the al tube. (more to come)
Does it have the built in intercooler like ours does?
Also how does it apply to the M113k that already has an AMG supercharger in it?
I am just waiting to decide on what injectors to get then get the re-tune and hopefully that solves my problem
You replace the AMG supercharger with bigger blower. More power.
I plan on getting this so if anyone wants my blower with 3 pullies, ported supercharger inlet, 82mm tb and custom maf housing send me offers in pm
http://www.ebay.com/itm/High-Precisi...#ht_1714wt_907
I'll see if I can simply plug in this 2k ohm var resistor in place of the factory 1k ohm var resistor:
http://www.ebay.com/itm/5-pcs-3296-W...ht_2454wt_1165
Cory is sending me a stock 2.8" pulley to put on during the winter months to keep this tune happy, and so I can actually track the car safely.
I know I'll lose 20-40HP.... but I want pc of mind, particularly with my inj being @ 100% duty cycle, my MAS pegging.... I am on the edge.
