Ultimate Guide to the w213 AMG E63 - Issues/Fixes/DIY
Old Jan 9, 2025 | 03:15 PM
  #101
PeterUbers's Avatar
ANOTHER DISCUSSION ON E53 LONG TERM RELIABILITY:
https://mbworld.org/forums/w213-amg/...id-system.html
Old Jan 10, 2025 | 05:11 PM
  #102
PeterUbers's Avatar
USED E53 CONSIDERATIONS BEFORE PURCHASE:
https://mbworld.org/forums/w213-amg/...g-e53-amg.html
Old Jan 17, 2025 | 02:02 PM
  #103
PeterUbers's Avatar
E53 POPS AND CRACKLES DISAPPEARED RANDOMLY - SOLVED
https://mbworld.org/forums/w213-amg/...sappeared.html
Old Jan 31, 2025 | 06:43 PM
  #104
PeterUbers's Avatar
2020 E63 with RMS LEAK:
https://mbworld.org/forums/w213-amg/...ml#post9105003
Old Feb 5, 2025 | 02:31 PM
  #105
PeterUbers's Avatar
REOCCURRENCE OF RMS LEAK AFTER INITIAL REPAIR:
https://mbworld.org/forums/w213-amg/...ml#post9108009
https://mbworld.org/forums/w213-amg/...ml#post9060845
Old Feb 5, 2025 | 10:12 PM
  #106
PeterUbers's Avatar
NEW PART NUMBERS FOR RMS AND OVS:
https://mbworld.org/forums/w213-amg/...ml#post9012993
Old Feb 8, 2025 | 07:29 PM
  #107
PeterUbers's Avatar
ENGINE INTERMITTENTLY HAS NO/LOW BOOST:
https://mbworld.org/forums/e-class-w...rift-mode.html
Old Feb 11, 2025 | 10:43 AM
  #108
SM105K's Avatar
2019 E63S and 2014 CLS 63S
You are a hero @PeterUbers
Old Feb 14, 2025 | 01:18 PM
  #109
PeterUbers's Avatar
COOLANT COLOR - APPEARS BROWN IN RESERVOIR BUT IS PINK
https://mbworld.org/forums/w213-amg/...reservoir.html
Old Feb 14, 2025 | 04:04 PM
  #110
PeterUbers's Avatar
M177 RMS ONGOING DISCUSSION - C63 RARELY AFFECTED:
C63 M177 LS2 ENGINE USES DIFFERENT OIL SEPARATOR THAN E63 M177 LS1 ENGINE
https://mbworld.org/forums/c63-c63s-...ml#post9064655
Old Feb 14, 2025 | 06:18 PM
  #111
W205C43PFL's Avatar
Interesting didn't know about that at all.
Old Feb 18, 2025 | 11:26 PM
  #112
PeterUbers's Avatar
REAR CERAMIC BRAKE PAD REPLACEMENT DIY E63
https://mbworld.org/forums/w213-amg/...placement.html
Old Feb 20, 2025 | 09:40 PM
  #113
01feds's Avatar
Warning for Anyone Buying a 2020 E63S – RMS Leak
Just a heads-up for anyone considering an E63S: my 2020 E63S with only 16,000 km had an RMS (rear main seal) leak. I got it fixed under warranty a few months ago, but it took Mercedes a full month to complete the repair.
Pretty disappointing that they haven’t issued a recall for such a common issue on these models. If it wasn’t under warranty, the repair would’ve cost over $10,000 CAD. Hope no one else has to deal with this.
Old Feb 21, 2025 | 07:14 AM
  #114
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
No, no one but anyone with the 4.0 variants before the new old separator.
Old Feb 21, 2025 | 09:02 AM
  #115
01feds's Avatar
Do you mean the new oil separator introduced in 2019 with the LS2? If so, while it’s true that Mercedes updated it with better sealing materials, it’s still prone to leaking. My car had the issue at just 16,000 km, which is extremely low for such a problem.
Old Feb 25, 2025 | 11:02 AM
  #116
PeterUbers's Avatar
FAQ ON CPC, TCU, AND TUNING PEARLS
https://mbworld.org/forums/w213-amg/...c-s-tcu-s.html
Old Feb 25, 2025 | 01:43 PM
  #117
PeterUbers's Avatar
RMS Fail Club - DATABASE OF AFFECTED VEHICLES
https://mbworld.org/forums/w213-amg/...fail-club.html
Old Feb 25, 2025 | 05:58 PM
  #118
PeterUbers's Avatar
Considering an E53?
48 VOLT BATTERY ISSUES (ACROSS THE BRAND)
https://mbworld.org/forums/cls-coupe...y-problem.html
Old Feb 26, 2025 | 02:32 PM
  #119
PeterUbers's Avatar
ANOTHER "SHOULD I BUY A USED E53?"
https://mbworld.org/forums/w213-amg/...-2019-e53.html
Old Feb 26, 2025 | 08:58 PM
  #120
PeterUbers's Avatar
E53 BURNED/MELTED WIRE HARNESSES
https://mbworld.org/forums/w213-amg/...tuned-cpc.html
https://en.mercedesassistance.com/misfire-in-engine/
Old Feb 26, 2025 | 11:08 PM
  #121
VCA_AMG's Avatar
2018 E63S Wagon
Originally Posted by bobblehead
18 and 19 are known to have RMS. If the car has no extended warranty, then factor in about $10k for potential repair on this one task.
‘Been reading posts about this rms failure for an hour and still unsure…was this problem limited to the 18s and 19s only?
Old Feb 26, 2025 | 11:38 PM
  #122
PeterUbers's Avatar
you must have missed it ...
post #95
https://mbworld.org/forums/w213-amg/...ml#post9083594
post #104
https://mbworld.org/forums/w213-amg/...ml#post9105995
post #113
https://mbworld.org/forums/w213-amg/...ml#post9115855
Old Feb 27, 2025 | 10:33 AM
  #123
PeterUbers's Avatar
PTSS CASE NUMBER FOR DEALER TO REFER TO WHEN REPAIRING RMS LEAK
https://mbworld.org/forums/w213-amg/...ml#post9119059
Old Mar 7, 2025 | 04:36 PM
  #124
PeterUbers's Avatar
MICHELIN PILOT SPORT S5 M01 REVIEW
https://mbworld.org/forums/w213-amg/...rt-s5-mo1.html
Old Mar 17, 2025 | 02:15 PM
  #125
PeterUbers's Avatar
HIGH PERFORMANCE SUMMER TIRES, OR ALL SEASON TIRES, THE [ONGOING] DEBATE
https://mbworld.org/forums/w213-amg/...ires-e63s.html
