---> CALI's hands-on ... STABLE CHASSIS VOLTAGE !!!
Old Jan 16, 2025 | 07:02 PM
  #101
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
That is sweet to hear : )
Me on the other hand is missing out...
Not for long
success is coming your way.
MS! has been disconnected for years to prevent "drained by driving"... no issue with 14.15V boiling off hydrogen. He has opened a thread for battery test.
12.6V float voltage is better than 14.15V for the chemistry but that's what regulator self-control does.
If we had only a stable 12.6V ECU would adapt ignition timings to it.
What's bad is the great GDI ECU is no able to adapt to that moving target.
ECU adapts a lot of attributes of the ignition multi-sparks but can not deal with the spark variability caused by changing primary coil voltage.
The spark voltage spikes change the precise timing... super touchy.
Old Jan 16, 2025 | 07:07 PM
  #102
W205C43PFL's Avatar
Not for long
I will try again tomorrow : ) when I have some sunlight in the garage.
Old Jan 16, 2025 | 07:08 PM
  #103
W205C43PFL's Avatar
Originally Posted by JettaRed
So, the SL400 seems to keep improving. Super cold today with all fluids below freezing at startup (shoulda taken a picture), but shifts were smooth and quick. I was expecting some thumping shifts while the engine and tranny were still cold, but no. As a matter of fact (perception), the car seems to operate better overall.
By the way, I have asked @crconsulting to take a look at this thread and provide any comments since he seems familiar with battery charge balancing and I was wondering if disconnecting the alternator LIN line would screw anything up. But didn't @S-Prihadi post elsewhere that his alternator line has been disconnected for quite some time now?
This thread? https://mbworld.org/forums/e-class-w...d-timeout.html
Old Jan 16, 2025 | 07:11 PM
  #104
W205C43PFL's Avatar
nevermind it was this thread: https://mbworld.org/forums/e-class-w...tire-life.html
Old Jan 16, 2025 | 07:39 PM
  #105
W205C43PFL's Avatar
@Manny_c450 Any success? Although I am unable to successfully get it done today, I still hope you were successful.
Old Jan 16, 2025 | 08:20 PM
  #106
Manny_c450's Avatar
C450
Putting son to sleep then I will get to work in the cold -10C garage and report back hahaha
Old Jan 16, 2025 | 08:25 PM
  #107
W205C43PFL's Avatar
Good for you Your car will reward you if you are successful, best of luck, you got this!
Old Jan 16, 2025 | 08:38 PM
  #108
COIL UPGRADE ???
Not for long
While we dealing with spark timings, the essential contributors are the advanced COP's with built-in MOSFETS.
I wonder if the factory coils can be thought of being crappy weak ??
I know their windings insulation get cooked and breached by extreme heat but I don't know that they can be classified as barbone cheap...
By no mean do I have any misfires, quite the opposite!
We know it's really tough to ignite a lean mixture.
Ignition timing is based on both mixture + spark voltage to ignite combustion.
I just wonder if COP upgrades would yield tougher multi-sparks. I am talking "knock it out of park" type of sparks vs. economy OE style.
The way MB things appear disabled, I dont want to overlook obvious items, like 70/30% chance.
Old Jan 16, 2025 | 10:00 PM
  #109
Manny_c450's Avatar
C450
Mine looks identical to yours, hand got to the connector but not able to get enough leverage to really pull anything off .I thought I had the clip by feel but not sure.
Will have to try from the bottom unfortunately.. maybe tomorrow.
Old Jan 16, 2025 | 10:04 PM
  #110
W205C43PFL's Avatar
Interesting but I don't feel any clip at all, you felt something? Why does our cars' connector look so different to forum member CaliBenzDriver and JettaRed's?
If you do end up going from the bottom tomorrow please kindly do take picture of how it looks from the bottom so we can figure out this mystery. Much appreciated!
Thanks for your update tonight.
Old Jan 16, 2025 | 10:07 PM
  #111
W205C43PFL's Avatar
and you have the same ziptie as well? Interesting ...
Thankfully seems like tomorrow is warmer.
Old Jan 16, 2025 | 10:11 PM
  #112
Manny_c450's Avatar
C450
Yeah looks the exact same. All of these Mercedes connectors are a pain , and everything is always tight.
I really wanted this connector off tonight hahaha.
Old Jan 16, 2025 | 10:20 PM
  #113
W205C43PFL's Avatar
Ya for sure, I am not sure why our cars have a ziptie installed as well, not sure why is it so different (cone shape) than anything we seen so far and not sure when they (MB) started doing that which makes it more difficult and confusing.
Ya I understand your pain of wanting to get it done tonight, I wanted to too but I lost daylight and my garage is poorly lit, worse was my back pain.
Old Jan 17, 2025 | 12:47 AM
  #114
ALT-LIN
similarities
similarities
your connector looks similar except I'm missing a ziptie on the crown.
  • same barrel
  • same lock
  • same harness
  • mounted 90° side vs. rear
Old Jan 17, 2025 | 10:28 AM
  #115
W205C43PFL's Avatar
https://cimg6.ibsrv.net/gimg/www.mbworld.org-vbulletin/1080x1105/screenshot_20250116_211317_chrome_b3f4764dbd36fe37 d9e4241d7463a17a1b9355e1.jpg
similarities
  • same barrel
  • same lock
  • same harness
I too wish it was the same thing : ( but how do you explain this cone thing, if it is some rubber protector or something, how do I get it off to reveal the familiar plug? https://cimg2.ibsrv.net/gimg/www.mbw...ea654545a4.png
Old Jan 17, 2025 | 10:30 AM
  #116
W205C43PFL's Avatar
If you do end up going from the bottom, please do (if you can) please take a picture of the connector from the bottom and show me and us, it will be much much appreciated and will help a lot to solve the cone mystery and we can see why our connector is different to anything we seen, and why is it designed differently. Thanks in advance!
Old Jan 17, 2025 | 10:33 AM
  #117
JettaRed's Avatar
Veteran: Army
I think that is just part of the connector and the zip tie is to provide strain relief.
Old Jan 17, 2025 | 10:36 AM
  #118
W205C43PFL's Avatar
I see, but how come yours and everyone elses' is flat and ours is cone shaped?
Old Jan 17, 2025 | 11:22 AM
  #119
JettaRed's Avatar
Veteran: Army
Here are some more pics from my 2015 SL400. What year cars do you coneheads have?
Top view looking down from front of car.
Old Jan 17, 2025 | 11:42 AM
  #120
W205C43PFL's Avatar
Mines a 2017 and the other forum member's C 450 is a 2016.
Old Jan 17, 2025 | 11:46 AM
  #121
W205C43PFL's Avatar
Ya I wish ours looked like that, that would had been a dream come true but ours is a cone shape and no clip to be found. Maybe it will look different from the bottom but even from the top looks nothing like what you shown us. Hopefully forum member Manny_c450 will be able to show us how it looks from the bottom and successfully get his unplugged.
Old Jan 17, 2025 | 01:10 PM
  #122
SMOOTH + STRONG POWERTRAIN
This is great shot, txs JR!
We see the side mounted connector near ALT +12V OUT-Stud
The "cone hat" is just for harness strain relief on top of exactly the same connector.
As long as it's single wire it's a go for your case!!
(Dual wires need investigation).
The blue ALT-LIN wire home-runs all the way up to ECU were you can switch it On/Off.
+++ Test drive: dynamic self-adaptations !
-- Everything is going in the right direction of ECU/TCU improvements
-- The interactive work of engine learning better fuel map, throttle responsiveness then tranny matching gears does take time just like oil MOD.
Meaning improvements begin right away but take time to settle in for best behaviors we like. Something like 1kMi range. Great driveability with a hint of goofiness in low gear.
-- Throttle improvements are interactive between engine > tranny > engine > tranny > engine...
>>> When you test drive what MOD + ALT-LIN bring back to this platform you understand powertrain is not compliant with variable pressure/voltage. It needs normal stability to work well.
Old Jan 17, 2025 | 05:52 PM
  #123
W205C43PFL's Avatar
Unsuccessful, my back killing me from the top can't imagine crawling down to do this. Can't find tab, can't rid of that protective cone hat you mentioned, I started working on it since noon today till sunset, I am getting nowhere. Hopefully forum member Manny_c450 has better luck. Eager to hear him reporting back.
Old Jan 17, 2025 | 05:53 PM
  #124
W205C43PFL's Avatar
I am starting to wonder if MB started making it a permanent plug, hopefully not but I am not as optimistic as you : (
Old Jan 17, 2025 | 06:12 PM
  #125
Manny_c450's Avatar
C450
trying later today, the temps are way more decent today. Did you try from the bottom this noon?
