Ultimate Guide to the w213 AMG E63 - Issues/Fixes/DIY
#51
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
RELIABILITY OF A TUNED W213 AMG E63S
https://mbworld.org/forums/w213-amg/...liability.html
#52
E53 COLD START METALLIC RATTLE
https://mbworld.org/forums/w213-amg/...-rattling.html
#53
2020 AMG MISFIRING DUE TO BAD GROUND POINT
https://mbworld.org/forums/coupe-roa...-stalling.html
#54
2023 ROUGH IDLE ONLY WHEN COLD - SOLVED - EXHAUST CLAMPS ISSUE
https://mbworld.org/forums/w213-amg/...ml#post9031296
#55
https://mbworld.org/forums/w213-amg/...ml#post9031358
PeterUbers (09-12-2024)
#56
#57
E53 DISCUSSION ON 48V SYSTEM ISSUES:
https://mbworld.org/forums/w213-amg/...mistake-2.html
#58
CAMBER BOLTS DISCUSSION
https://mbworld.org/forums/w213-amg/...ber-bolts.html
#59
FRONT SUSPENSION
#503416-1i $345 (Both Sides)
CAMBER ONLY
(less cost then one quality tire)
#503416M $595 (Both Sides)
CAMBER & CASTER
Also this Camber and Caster kit replaces at same time the 4 front highest wearing bushings. The forward facing “Caster” bushes K-MAC are also Mono ball / Self aligning replacing the OEM soft rubber - therefore still allowing arms to travel though their required suspension arcs but significantly improving Brake and Steering response.
REAR SUSPENSION
#502326-1K $480 (Both Sides)
CAMBER & “EXTRA” TOE
Both Front and Rear K-MAC kits require no special tools or need for time consuming control arm removal.
Also retaining existing OEM high strength forged alloy arms for security - not replacing with welded / fabricated arms and subsequent warranty issues.
Unique K-MAC patented design also allows “easily accessible” - single wrench adjustment. ULTIMATE - Direct on alignment rack UNDER LOAD !
DHL Express Air Worldwide $40 one kit ($20 each extra).
sales@k-mac.com ….web: www.k-mac.com ….1888 847 9099 (Sales Tech 24/7)
AUDI to VOLVO - K-MAC Experience Resolving OEM Suspension Shortcomings (and Costs) Since 1964 !
#60
DRAGY MEASUREMENTS
https://mbworld.org/forums/w213-amg/...results-2.html
#61
ANOTHER AGGRESSIVE INNER TIRE WEAR
https://mbworld.org/forums/w213-amg/...r-bolts-3.html
#62
NEED TO ADD COOLANT
https://mbworld.org/forums/w213-amg/...g-coolant.html
#63
AMG DRIVE UNIT ON STEERING WHEEL STOPS WORKING AFTER DEAD BATTERY REPLACED
https://mbworld.org/forums/w213-amg/...l-buttons.html
#64
ANOTHER MCT JERKY IN S+
https://mbworld.org/forums/w212-amg/...eleration.html
#65
Z23 PADS INSTALLED AT 30k MILES, KEPT SAME ROTORS:
https://mbworld.org/forums/w213-amg/...zero-dust.html
#66
ANOTHER EXHAUST UPGRADE DISCUSSION
https://mbworld.org/forums/w213-amg/...w213-e63s.html
#67
#68
CREDIT FOR MISSING ITEMS ON BUILD SHEET
https://mbworld.org/forums/w213-amg/...g-options.html
#69
P0238, P0240 - BOOST PRESSURE SENSOR
https://mbworld.org/forums/w213-amg/...stage-3-a.html
https://mbworld.org/forums/w213-amg/...sue-p0240.html
#70
JACKING POINTS
https://mbworld.org/forums/w213-amg/...-location.html
#71
BLACKBOOST GEN 2 INTAKES
https://mbworld.org/forums/w213-amg/...m177-e63s.html
#72
STOCK 2018 DYNO GRAPH
https://mbworld.org/forums/w213-amg/...dyno-runs.html
#73
REPAIRING LOOSE USB OUTLET
https://mbworld.org/forums/w213-amg/...sb-outlet.html
#74
AUTOFOLDING MIRRORS STOPPED WORKING (WITH FIX):
https://mbworld.org/forums/w213-amg/...working-3.html
