SL55/63/65/R230 AMG: DIY Thread for the R230 SL55/SL65 AMG
Rating: Thread Rating: 2 votes, 5.00 average.
Old 02-08-2013, 06:36 AM
RAWAMG's Avatar
SL55 AMG EC Stage 5 Beast / ESS S/C E92 M3
Originally Posted by overZealous1
so who is going to add the next diy? i would, but in the past i have tried and i do a before and after pic and thats all. i am too busy fixing it to take pics during! haha.
Well... I just got a STAR DAS & I know that I will be spending A LOT of time on the W211 thread looking at their STAR DIY... I Think that we should for sure have one of those as a STICKY on here & I will certainly contribute BUT it won't be until I have done my due diligence and learned how to use it (probably the hard way)
What do you have to do to get a thread to be STICKY anyway??? any moderators or administrators want to chime in here? Can we please get this DIY as STICKY??? I would like to log in & not have to search for it when I need it
Old 02-27-2013, 02:22 AM
jagata's Avatar
S6 LP640 E500
Originally Posted by RaFFi ///AMG
Can we sticky this.
Why is this not a sticky?
Old 03-13-2013, 09:50 PM
Rick SL55's Avatar
2005 SL55 AMG, 1986 Porsche 930S, 1996 Porsche 993tt
StIcKy!!!
Old 03-14-2013, 04:48 AM
RAWAMG's Avatar
I just sent PM to moderator...
Old 03-14-2013, 07:34 AM
RAWAMG's Avatar
Thanks ROCK for making it "Sticky"
Old 05-23-2013, 07:18 AM
Administrator
Rock's Avatar
Drives Slowly
Another:
https://mbworld.org/forums/sl55-amg-...nance-diy.html
Old 07-09-2013, 02:09 PM
  #32
B-tsai's Avatar
CLK320, ML550, SL55, GL450
Rear Window Delaminated Side Trim Replacement
https://mbworld.org/forums/sl55-amg-...ement-diy.html
Old 10-12-2013, 12:24 PM
  #33
B-tsai's Avatar
HFELIU just posted this:
Rear Axle Fluid Change
https://mbworld.org/forums/sl55-amg-...id-change.html
Old 10-19-2013, 07:51 PM
  #34
B-tsai's Avatar
VTVETTE just posted this:
ABC Fluid Flush
https://mbworld.org/forums/sl-class-...placement.html
Old 11-16-2013, 04:36 PM
  #35
OMGMOVE's Avatar
Install new battery?
Old 09-28-2014, 06:13 PM
  #36
B-tsai's Avatar
number_one_c55 just posted this:
XENON MODULE REPAIR INSTRUCTIONS! FSL11N50A
https://mbworld.org/forums/clk55-amg...fsl11n50a.html
Ducatic230 (05-04-2020)
Old 10-20-2014, 01:13 PM
  #37
B-tsai's Avatar
Loose Baffle in gas tank
Found this one from contributors:
super_monkey
Wettig10
NikleinR6
iammalibuboy
simply awesome...
https://mbworld.org/forums/sl55-amg-...-gas-tank.html
Old 10-25-2014, 09:22 PM
  #38
SGTzAMG's Avatar
02 C32 AMG, 05 SL55 AMG, 09 SL63 AMG, 14 E350, '18 G550, 92 300ZX & 15' GL63 AMG
how about lowering links install DIY?
Old 12-21-2014, 03:54 PM
  #39
Dave in VA's Avatar
2011 SL65 & a 2018 C63s
Do anyone have a link to the OBD-II software, for our cars?
Dave
Old 12-02-2015, 04:15 PM
  #40
Earl J's Avatar
Location: SF Bay Area, CA & Northern New York (2nd home)
2007 SL55 w/030, 2014 B Electric, 2012 ML350, 1965 Shelby GT350 w/48IDA Webers, previous 06 SLK55
DIY for Console Trim Removal ?
Hello,
Does anyone have a DYI instruction for removing the center console trim? My 2007 SL55 factory carbon trim is starting to delaminate behind the console shifter and back towards the top lowering lever in front of the center compartment.
Has this happened to anyone of you? My thinking is; if I can remove the trim I can repair it by epoxying it to the fiberboard backing and clamp it until it cures. Thanks in advance.
Cheers,
Earl J
Old 12-03-2015, 12:01 AM
  #41
Nosmo SL55's Avatar
2004 (MY05) SL55
Originally Posted by Earl J
Hello,
Does anyone have a DYI instruction for removing the center console trim?~
Hope this helps
Old 12-03-2015, 09:52 AM
  #42
Earl J's Avatar
Originally Posted by Nosmo SL55
Hope this helps
Thank you Nosmo SL55, this is exactly what I was looking for.
Cheers,
~Earl J
Old 06-08-2016, 04:22 PM
  #43
MarkF1's Avatar
2007 sl55
Sl55 service manual codes
For every service activity in the mb service manual there is a final column with a four digit number, for example, ABC fluid service is 3213, steering and boot inspection service is 4653. Does anybody know what these numbers are reference to? If they are to MB procedure how can I get copies or a set? I live in remote NM town far from MB mechanic - I am well intentioned but dangerous with a wrench but dead set to do my own service work.
Old 04-03-2017, 08:06 AM
  #44
byronburns's Avatar
2003 sl55
trunk carpet removal
Does anyone have a DIY for removing the trunk carpet above the roof hydraulic pump? I have it completely detached from fasteners. it would seem that you have to remove the roof brace/trunk hinge to get it out. Any help would be appreciated.
Old 04-04-2017, 04:37 AM
  #45
desired_speeds's Avatar
2007 SL55 AMG
You have to put the trunk into service mode. Check out this video:
Old 09-11-2017, 11:41 AM
  #46
wrightbenz's Avatar
SL55 SLK 320
Originally Posted by kamilclk430
So the guys in the E55 W211 AMG section have a sticky on a bunch of different DIY goodies. I want to make one for the SL55/65 Section as well. So here are all the different DIY I provided to the forum and also that others have over the time. Please add any DIY you can to this thread.
DIY: OIL CHANGE SL55 (VIDEO)
http://www.youtube.com/watch?v=C_4R0SFS-Q0
DIY: Side Mirror Removal
https://mbworld.org/forums/sl55-amg-...s-removal.html
DIY: Front Lip/Spoiler Install
https://mbworld.org/forums/sl-class-...p-spoiler.html
DIY: Removing Side Trim
https://mbworld.org/forums/sl55-amg-...nels-r230.html
DIY: Cleaning Exhaust Tips
https://mbworld.org/forums/sl-class-...aust-tips.html
DIY: Vario Roof Not Working FIX
https://mbworld.org/forums/sl55-amg-...y-fix-diy.html
DIY: Trunk Soft Close/ Trunk Assist FIX
https://mbworld.org/forums/sl55-amg-...w-fix-diy.html
DIY: Alarm/Siren Issues FIX
DIY: V12 SL Models Only (Motor Mount Replacement)
https://mbworld.org/forums/sl55-amg-...sl-models.html
DIY: Dyno Mode (03 SL55 AMG)
https://mbworld.org/forums/sl55-amg-...-mode-diy.html
DIY: Easy Semi-hardwire for Aux Input through Ashtray
https://mbworld.org/forums/sl55-amg-...h-ashtray.html
DIY: Painting Brake Calipers
https://mbworld.org/forums/w211-amg/...-calipers.html
DIY: 82MM Throttle Body
https://mbworld.org/forums/w211-amg/...ttle-body.html
DIY: Front Pad and Rotor Replacement
https://mbworld.org/forums/w211-amg/...placement.html
https://mbworld.org/forums/sl-class-...-question.html
DIY: QUAIFE INSTALL
https://mbworld.org/forums/w211-amg/...e-install.html
DIY: Changing your IC pump to a Johnson CM30 or Any other Pump
https://mbworld.org/forums/w211-amg/...nson-cm30.html
DIY: Removing Scratches from Head Unit
https://mbworld.org/forums/w211-amg/...nd-screen.html
DIY: Updating your 3rd Brake Light to SL63 Clear
https://mbworld.org/forums/sl-class-...-cost-new.html
DIY: Pulley Install
https://mbworld.org/forums/w211-amg/...y-install.html
DIY: Replacing Tail Lights
https://mbworld.org/forums/sl-class-...implified.html
DIY: Voltage Regulator Replacement
https://mbworld.org/forums/w211-amg/...lternator.html
DIY: S/C Clutch Install
https://mbworld.org/forums/w211-amg/...h-install.html
DIY: ECU RESET
https://mbworld.org/forums/w211-amg/...set-works.html
DIY: Supercharger Belt Replacement
DIY: Valve Cover Gasket, Plugs, and Wires
https://mbworld.org/forums/w211-amg/...lug-wires.html
Several of these links are no longer valid. Another issue many of the photos are no longer there.
Old 12-03-2017, 05:19 AM
  #47
SGTzAMG's Avatar
Xenon bulb replacement
Do have anything for xenon bulb replacement?
Old 05-21-2019, 11:45 PM
  #48
Firstclasstranz's Avatar
Slk55/s65
Camshaft positions sensor
Can some please make a camshaft position sensor one I’m stuck here lol
Old 06-07-2019, 01:16 AM
  #49
Rzbenz's Avatar
2004 SL55
“Missing” idle and A/C issues
Hey all. Have an ‘04 SL55 that I recently purchased and I’m chasing some issues. First off is a “rough” idle issue. It literally sounds like I’ve dropped a cylinder but my MB shop said their not showing any evidence of a miss on their computer. Also the car just made 510hp and 570lb/ft at the wheels so apparently it’s not running too poorly. Someone suggested it’s a cam but I’ve never heard a cam sound like a dead hole. Second issue is the A\C only blows cold when moving at a good pace. If I get stuck in traffic it stats to blow warm air. I live in AZ so obviously I’m dealing with substantially warmer ambient temps but none the less I’d like to think a car of this caliber is capable of blowing cold air even in triple digit temps while stuck in traffic. Anyway, I’m sure there are a ton of details I’d need to supply in order to give someone a good shot at helping me figure out what’s going on but I suppose I can dole that out when asked. Thanks in advance.
Old 06-07-2019, 01:54 AM
  #50
wrightbenz's Avatar
SL55 SLK 320
Maybe you have a loose spark plug. Worth a look it will cause a noise like you described.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: SL55/63/65/R230 AMG: DIY Thread for the R230 SL55/SL65 AMG
