View Full Version : GLK-Class (X204)
- Rearview Camera Retrofit NTG4.0, Aux programming
- GLK 2010 350 tires
- ✅ GET YOUR Transmission Agility mode and More for FREE!
- GLK250 transmission ISM dealer programming?
- switched power for Dash cam?
- Front Driveshaft...here we go....
- replacing seat cover, but with heated seats
- Service/inspecting without taking wheels off
- X204 Won't start
- Spare tire
- Mystery part
- Front Suspension Rebuild Time
- NO VACCUM AT TURBO SOLENOID VALVE INLET
- Need help! No start! No crank! (Video Included)
- 2015 GLK 350 4MATIC Oil Pan Replacement
- Strange sounds from the back of the car
- Automatic trunk opens all the way and then drops
- What would be a fair market price on this super clean 2010 GLK 350, with only 79k mil
- 2015 GLK 350 Odd Transmission Behavior
- oil spots are not good
- EGT sensors
- Headlight upgrade to LED
- 2015 M276 Coolant Issue
- Wheel bolts torqued and fell out !!!!
- 2015 mercedes glk350 Need help with rear right door handle cable
- Radio issue
- 2012 GLK 350 Transmission Pan Torque Value
- 5.8" to 7.0" screen upgrade
- MB vs Aftermarket Battery?
- P20BD code on GLK250
- Wheel bolts
- 2015 mercedes glk350 oxygen sensor 1 bank 2 location
- GLK350 won’t shift out of Park
- 2013 GLK350 no esl?
- P008A returns after fuel filter change
- Steering wheel issue
- GLK350 Error Codes
- Glk350 reliability/equipment questions
- Death Wobble
- Headlight switch with front foglight switch
- Where are the GPS files stored in a GLK?
- Recommended sockets for mb mechanics?
- Yearly Front PS Caliper failure?
- 2010 GLK 25k miles
- Odd vibration while turning
- 2013 GLK 350 Transfer Case
- 2014 Keyless Go issue
- I what size tire do I need , I have 235-50-19
- 2012 GLK 350 won't read obd
- Greasy wheel center caps
- Rain sensor standby?
- Headlights - When should each bulb illuminate?
- P261F haunting me again
- Roof Rack Specifications for Ballista
- Bottom Seat covers installed
- 2012 Glk 350 driver seat heater lower wire broken off
- tires 235/45 R20 vs 245/40 R20
- 2010 X204 Erratic Electrical Issues, diffucult start, cannot go in gear
- Added highbeam ledbar update
- Seat heater too hot
- P204ffb code
- GLK 350 shudder - transfer case question
- No Aux or MMI input connectors
- 2015 GLK 250 - Part number A 204 885 3374
- New tires 19 or 20”
- Digital Dash
- Seeking good Indy in Santa Fe/Albuquerque
- Seat Covers
- New Brake Pads
- '13 GLK350 misfires #1,#2, sooty #3
- Black Friday/End of Year Sale 2023 – OE Tuning
- Misfire and can't read short term fuel trim.
- 2015 GLK, NTG4.7 nav update method?
- 2011 GLK350 Headlights
- Should I replace TPMS
- TPMS issues
- Lower radiator hose leak
- Fixed brake pulsing without grinding the rotor !
- Replace brake pads at 50%
- E350 Sport Steering Wheel Swap on 10-12 GLK
- GLK vibration issues
- Help: Right DRL is failing some times
- 2011 GLK 550 Build
- Help - Custom Tail Lights on '10 GLK
- glk 350 bumper upgrade?
- Airbag recall- then Front Right SRS malfunction
- Metris wheels on a GLK
- New GLK 250 Owner
- Water pump help
- Rear View Camera cuts in and out
- 2013 GLK350 Multifunction Display UP/DOWN button malfunction
- Help! Repair Shop Broke my Rack and Pinion - Now making an odd noise
- Brake rotors not warped?
- GLK vs. iPhone 15?
- Radiator Leaking
- Hatch Struts last how long?
- MB brake pads not available FCP euro
- Stock radio head unit cross-reference?
- Easy Carplay/Android Auto addition
- Bad rear diff bearing diagnosis
- Lost Disc and Memory Card when updating GPS files
- Is this a bearing failure or an oil pan failure?
- low beam won't turn off after HID kit
- 2015 GLK - lighting upgrade (halogen to aftermarket LEDs)
- Misfire on cylinders 5 and 6
- Need help with what kind of leak is this
- Ticking noise om651
- Glk250 oil
- Why is this happening?
- Transmission is I n park, but it it says it’s not like the door is open ?
- Audio Upgrade/Subwoofer/HK System
- 2011 GLK 350 Wood Trim Removal
- Timing tensioners
- 2010 GLK350 Rear Coil Springs Help!
- Engine Oil Dipstick Tube Leaking
- Unexpected Rust - Check your GLK for this
- CV Axles - Some Quick Thoughts
- Stiffer rear and raise
- Does your glk sound like this?
- Full tank gas smell, no leak
- Replacing the back brake lines
- Sudden short loss of power from time to time
- 2011 GLK350 intermittent A/C issue
- 2008 GLK 220 CDI Camber adjustment
- Front passenger window doesn't respond to driver door controls.
- Crankcase vent location and removal
- New Battery 2010 GLK 350 freaking out nothing working
- Glk 350 #1- Tops In Rating
- My startup rattle is gone
- PO0299 Turbo Underboost
- Winter grid heating pad
- 15 GLK250 Blind Spot Inoperative - unable to enable
- Plastic Chrome Door Trim Restoration
- FYI - Engine brake caused check engine light
- GLK250 P261f coolant / vacuum issue
- P203D how to replace sensor in DEF tank
- GLK250 cleans up good!
- Farewell, GLK!
- PO 430 Code, when it rains it pours...
- Sway bar upgrades 2015 glk 250
- Spare tire issue
- Front Rotor Diameter
- Yellowish Coat on Rear Differential
- ‘15 GLK 250 Bluetec Emergency Brake Light
- GLK250 Bluetec Engine Oil Leak
- Help- Reverse Camera Turns Off After 10 Seconds
- GLK ABS Brake Controller $$$
- GLK350 - what to look for?
- OBD Codes P205C, P2201 NOx SOLVED!!!
- Tire recommendations
- Best Phone Mount for GLK
- strut bolts?
- Booming sound from the back/Spare tire cover
- Radiator Fan on high and no ac
- GLK250 2014 (Service A) - can I skip it?
- Timing Error Codes Help
- ECU swap - original by STG2 tuned remotely
- Help identifying oil leak
- Driver Bottom Seat Split - Now What?
- Strut top plate Access?
- 2010-12 Black Housing Headlights
- Chain slap persists, startup rattle
- Inoperative, see owner's manual. No power. HELP!
- Climate control issue: no cabin air fan
- 2013 glk-250 Bluetooth not working
- A 2011 GLK has caught my eye
- 2015 Mercedes Benz Glk350 driver power seat and power steering wheel
- 2015 GLK 350 Apple CarPlay Question
- 2014 GLK250 starter replacement?
- 2012 GLK350 Radiator Grille Interchangeability
- GLK Door Hinge Gasket
- P0017
- Passenger side wirewall fan? staying on an hr after turn off.
- 2010 GLK350 Timing Chain Question
- P229F - nox sensor location?
- iPod control in GLK
- 2010 GLK 350 body upgrade
- M276 Bank 2 intake adjuster sprocket video diagnosis
- 2012 GLK350 No Start brake pedal stiff
- Headlight adjustment left / right?
- Car deficiency/problem scanner
- Power tailgate not working after battery disconnected
- ESP MODULE-GLK 350 4-MATIC
- What's that noise ???
- GLK 350 Offroad Wheel/Tire Setup
- Camshaft Sprocket part number verification
- 2010 glk 350 upgrade
- 2011 glk350 runs out of gas at 1/4 tank
- What size nuts are these?
- Drive GLK without rear propshaft?
- Greetings from SuperSprint Italy
- GLK 350 crankshaft position sensor code
- Chrome delete for window trims?
- 722.9 Transfer Case Bearing Preload
- Remove exhaust driveline center bearing
- NEED ONE 20'' RIM
- Sport seat reupholstery
- Brake EBD, ABS, and ESC Inoperative - wheel speed sensor anomoly?
- GLK similar to E350 (w212)?
- GLK250 Engine Shaking
- Battery tender for GLK350?
- Side Marker Bulb
- P0234 overboost
- GLK250, moving on unfortunately. Comparison with Tesla
- Adaptive high beam assist
- HELP!- Cam Position Sensor code storm!
- Fuel filter/fuel sending unit
- top side oil evacuator issues
- gear box and oil leak
- 2014 GLK250 Rear Coil Spring Replacement
- 🅱🅴🅽🆉🅽🅸🅽🅹🅰 ⭐⭐⭐⭐⭐ DIY DIAGNOSTICS, CODING & REMOTE ASSISTANCE ✅ USA's N°1
- Rear Ashtray / Cigarette Lighter Fuse Replacement ** Need Help **
- ESP Fail followed by Transmission Limp Mode
- 12 o'clock notch on a steering wheel
- Water Pump Software Recall
- Wiper parking positions
- 2014 with dreaded driver seat damage
- OH OH, I messed up
- Brakes: What other models/platform shares our rotors/pads/calper/etc
- New GLK350 Owner | Help Needed | Lots of Error Codes, Challenges
- duplicate post - mods please remove
- 2011 GLK350 4matic was in an accident
- Canadian Owners Emmisions AEM Recall
- Any pre-facelift owners still around?
- Need 2 new tires. Do I HAVE to replace all 4?
- GLE wheels on GLK X204
- VW Owner - Considering BlueTEC GLK250
- Electrical red flags in this Carfax?
- Where do you get touch up paint in Canada?
- GLK350 won’t start (battery recently replaced)
- GLK 250 transmission judder ~2000 rpm
- Rear Subframe "Extended Warranty" Thread
- Not going into park
- Strong Arm lists wrong parts for hood struts on their website
- Key Fob not recognized when inserted - GLK 350
- Knob rotation shaft replacement
- 2012 GLK350 transmission fluid check
- 2010 GLK350 ESP fail
- WDC VIN
- BlueDriver OBD2 for 2010 GLK350?
- No dip stick, just orange handled cap?
- Service required do not shift visit dealer
- Regular gas
- Help glk 250 engine warning adblue 10 starts.
- The planned obsolescence is real
- Bad Pcv valve ?
- M276 Turbo
- Steering wheel lock emulator
- glk 350 headlight replacement
- Recommendations 4 suspension specialists in LA/OC area
