View Full Version : CLK-Class (W209)
- Sport PKG = Sport Suspension??
- 2003 CLK 500 Hydro-Lock
- Radio
- Installing fender liner 209-884-13-22
- Help with Repairing BiXenon Low Beam Issue
- clicking noise on hard take off or braking
- Please help - car problems after having radiator replaced
- New tires
- Don’t brakes
- Will 15-inch Rims Work on a CLK550 ?
- Altitude pressure sensor signal -short circuit to ground
- W209 generator wear
- Four Wheel Alignment after New Tires
- 2000 CLK 320
- Intermittent Radio, CD player
- Does w203 Facelift dash parts fit w209?
- Comand 2.0 Navi Updates
- Groaning Noise When Turning
- Currently getting my car wrapped ... with Audi S series style side mirrors. Opinions?
- Front Suspension Rebuild
- Mystery Wires in Trunk
- Who has taken the center dome lamp/sensor assembly apart?
- remove AMG SLK200 rear bumper
- motor mount
- N103 ( A2098203226)
- Service Interval Reset
- power steering scare w209
- fuse box locations
- Key FOB not working
- Screws needed for undercar shield
- Mystery oil leak help
- Controls on driver door not working
- CEL came on reads Code P0300
- Clk320 tune
- Need help diagnosing hydraulic oil leak in Convertible
- Routing electric cutouts to rear fuse box
- General W209 reliability question
- W209 Ornament I'm Dying Here
- Fuel odor after fillup.
- CAN Bus Messages - Digital Cluster
- ***WannabeRacer.com | Boston and New Jersey Vinyl Wrapping Tour***
- W209 AIRBAG CONNECTION
- Headlight marks - See Photo
- Grinding noise when revved high or car under load changing direction
- FEELER: 2005 Mercedes-Benz CLK500 For Sale
- Steering Wheel showing wear
- Exhaust piping size
- Future Part Availability
- Headlight issue
- Uneven and dragging front brakes
- Mercedes W209- No CD Changer, No Tel Error
- Convertible Top not Retracting
- Phone Mount - Nice One I Found
- DIY - Mercedes W209 bouncing lock - repair through speaker hole.
- Should this trim be glued down?
- Tel Error on Command 2.0
- Time to check out of the MBZ hotel
- Does anyone know how to diagnose the phone cradle ?
- aux plug
- Evap Problem or something else
- Winter is Coming! But no heat!
- 722.6 Dipstick Position
- Door lock bouncing even after repair. What did i do wrong ?
- DIY - How to remove IR sensor (w203, w209) - without cutting anything!!!
- Ambient Lighting Footwells 2009 CLK350 Coupe
- safe to use regular gas - gas shortage
- side marker light
- Stolen recovered clk 500 ,no key
- ECU Tuning
- Brake comparison (mostly weight comparison)
- ESP CODES WHEN SCANNING CAR
- Help! CLK350 Drivers Window Stuck Up and Off Track
- Star ornament on the 04 CLK possible?
- 2004 CLK 320 power seat
- Seat belt extender arm broken.
- W209 mid-face Xenon headlights
- Removed CD changer - open fiber optic loop?
- TSW Rivage 18" wheels, 235's in front, 265's in rear...but rubbing...what size spacer
- A209 CLK320 2003 roof not quite closing correctly by rear windscreen
- Parts Catalogues.
- keyless go
- Carbon side skirts for CLK?
- how to set up garage door opener without the remote?
- MB coolant in a Japanese Motorcycle
- 2001 mercedes transmission control module
- Anyone running non staggered wheels?
- Garage door opener programing
- Would pioneer aftermarket head unit fit in 09 CLK?
- How to repair side dash covers + unbelievable Australia prices
- does this damage the top??
- Remove sunroof sun shade
- Center speaker grille vent
- P0172 and P0175
- Need a cls55 front wheel 19x8.5
- CLK55 Loss of Power Steering Fluid
- Anyone selling cls55 front wheel?
- 03 W209 differential help!! Destroyed it! 150mph
- Bose Radio Amplifier
- Clk350 rear speaker removal Help
- Thoughts?? '09 350cab to '15 c300 sedan
- Question on some W209 details.
- Auto lock not working--Fuse #8 blowing
- oil for mercedes clk 500
- CLK 270CDi Engine oil level dipstick
- Radio Nav replacement 2009 CLK350
- W209 radiator help
- Selling my 08' coupe with only 25K miles
- w209 crank, no start after Power Steering Pump Ground Cable Replaced
- Exhaust cut out for CLK55
- How much weight could be removed from a clk ?
- center channel
- AerowerkZ OE Replacement Front Struts for W209 CLK-Class
- Passenger seat removal. Disconnect battery or ensure ignition is off.
- ABS and ESP Currently unavailable
- Dead Battery / Cannot enter vehicle.
- Gear knob
- Code P0015
- M112, do I need to replace the harmonic balancer - Video inside
- Narrow tires on stock rims? (245 vs. 225)
- Will CLK63 Black Series Cool overs Fit
- M112 High RPM Wobble/Coarse Noise
- clk SAM module replacement
- 20 inch wheels for my Clk? Help
- front bumper removal
- spacer size
- FS: Used OEM CLK63 Black Series Spoiler Carbon Fiber
- c 230
- Soft Top Operation Diagnostic Aid
- 08 CLK350 U0101 Code
- Mercedes Benz EXKLUSIV an all Mercedes event - Sat. Sept. 9 2017. Long Beach, CA.
- anyone runnign E63 tips on there clk
- Exhaust idea
- Allen wrench for CLK headrest release
- Pre-facelift Distronic
- CLK 550 with sports suspension ...Sachs or Bilstein ???
- clk350 center console problem
- window problem 03 clk320
- bad starting problems
- Bluetooth Issues with D2B Command & UHI
- Discovered strange leak
- ***Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - Aug 28th - Sept 4th, 2017***
- clk320 window problem
- Power trunk needs help...
- Xentry mods
- Replacing convertible top
- 2004 CLK 240 Sometimes won't start
- Just Saying Hello and Looking For Advice
- How to enter engineering mode in COMAND
- W203 STEERING WHEEL ON A W209
- 08 350 CLK camshaft death, HELP PLS
- Car jerks when accelerating
- Voltage regulator replaced and still not charging
- engine oil flush..yes, no, or maybe?
- Need Help: Soft Top does not open
- How do you get the fan out?
- Track pads for CLK55
- MAF
- Rear SAM
- Battery or Alternator?
- E55 AMG supercharger
- CLK W209 Audio issue. Help!!!
- new owner here
- 2003 CLK320 fuel filter
- Command replacement - Most converter to use existing Amp. No sound
- Any advice before replacing battery - 2006 CLK 500 Convertible
- Need help with loose clips for convertible, please.
- Anyone had experience with extreme dimension body kit?
- Newbie in need of assistance
- Buying advice 2006 CLK350 Cab
- M112 Breather Hoses
- new aux cable for the current generation Iphone??
- FS - 2003 Clk55 AMG
- 2004 CLK 320, non Comand
- Engine fan not turning on - P2073
- AIR INLET TUBES
- Wind Screen for Sale
- roof rack options using factory mounting?
- FS: Used Euroteck Carbon front lip
- ENGINE RATTLING NOISE
- Turning off check engine light
- Possible Oil Leak, Need Advice
- air blower problems
- Options on a new MB
- left low beam headlamp replacement
- windshield washer pump not working
- Tires
- Car switch the power while driving and not only
- CLK Supension Help!
- 2005 CLK500 Performance and Visual Mods
- Rear headrests locked up
- Oil leak
- CLK500 help needed
- 2005 CLK 500 Cabrio - Various
- CRANK POSITION SENSOR LOCATION ON CLK 220 CDI?
- 2008 c300 sirius - no signal.
- Window Rattle
- 2006 CLK 500 AC mind of its own
- Gear box broken? won't change up or down CLK 500
- check my vin for 2007 mecedes c280
- 06 CLK 220 CDI Auto Intermittent Stalling Problem
- 2009 CLK350 top won't open
- gas
- Smoked much?
- Getting New Wheels and Tires - Need Advice
- Coolant leak, odd spot.
- Need confirmation ASAP
- W209 clk320 cabriolet top inop
- 2004 CLK Coupe: How do you adjust the rear windows?
- Coilovers advice
- Anti Roll Bar Wont Stay In The Up Position
- My 2008 w209 keeps having to be jumped off after setting a couple of days.
- Mercedes Benz 2006 ML 350 4 matic
- install subwoofer
- install subwoofer
- Anyone running et25 on their Mandrus wheels?
- Lens only for trunk brake light (W209, 2008 CLK350)
- New to me 09 CLK350: conductor plate replacement?
- (2) fenderes (2) side skirts (2) back bumpers
- Amy black series bumper on convertible?
- where can i get a clk63 convertible front bumper?
- sd card
- rear bumper cover and diffuser
- 270CDI 125kw Problems with engine/EPC/injektors :/
- Intermittent Trunk Latch Closure
- Ignition switch/key problem
- Is there a thru trunk on a convertible ?
- Jack Point Replacement
- W209 paint code?
- Hit a cat at 50mph
- Soft top cover half closed
- My 2009 CLK550 Project Car
- Carbon Fiber interior trim kit
- 2005CLK320 cabriolet no start
- CLK 280 Rear clunk in an empty trunk/boot
- Blower fan relay location
- Normal voltage behavior?
- Bulb Replacement for Fog Light
- Electrical? 06 CLK 500 - 90k+
- Need pull straps for cabriolet top
- what kind of Benz was Tiger driving?
- AC Contols intermittant
- CLK 320 2005
- 2005 clk 320
- 2005 clk 320
- Why are you hanging on to your W209?
- P0025 I kow it out there but .....
- Coolant Colour
- FCP Euro Memorial Day Sale
- Above average idle sound
